cffd(at)pgrb.com Guest
Posted: Thu Apr 29, 2010 5:46 pm Post subject: High and Slow |
I usually fly low between 1000 and 2500 ft. AGL. But the other day I wanted to see what my Jabiru 2200 powered CH 701 could do. I climbed to 10,000 ft. (11,300 density altitude), final climb rate at 10K was 200 to 300 ft/min. Engine was smooth all the way and temps were good. Sure can see a long way from up there.
Having Fun,
Chuck D.
N701TX
ch701builder(at)yahoo.com Guest
Posted: Fri Apr 30, 2010 3:47 pm Post subject: High and Slow |
Thanks for the info Chuck. Since I live at 9,100' the majority of my flying will be around 10.5 and above. Not a whole lot of fliers up at this altitude, so I am having a hard time trying to find which engine would work best.
Keith
CH701 -- slow scratch builder
Sent: Thu, April 29, 2010 7:15:19 PM
Subject: High and Slow
Having Fun,
Chuck D.
N701TX
JohnDRead(at)aol.com Guest
Posted: Fri Apr 30, 2010 8:04 pm Post subject: High and Slow |
Hi Keith;
I live at 7200 feet and Stan Chalgren in Evergreen CO is even higher. We are both using the Jabiru 3300.
Regards, John Read
CH701 - Jabiru 3300 - Colorado
Posted: Sat May 01, 2010 9:09 am Post subject: High and Slow |
Hi John,
I knew that you were using the 3300, but I didn't know what Stan was using in his 701.
I still need to get out to Elbert sometime soon, to see your progress.
Keith
Woodland Park, CO
From: "JohnDRead(at)aol.com" <JohnDRead(at)aol.com>
Sent: Fri, April 30, 2010 10:03:49 PM
Subject: Re: High and Slow
Hi Keith;
Regards, John Read
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Mon May 03, 2010 7:48 am Post subject: Re: High and Slow |
Chuck. Stoppit. That’s too high. You could get stuck up there.
ggower_99(at)yahoo.com Guest
Posted: Mon May 03, 2010 10:49 pm Post subject: High and Slow |
Hello Chuck,
Welcome to my normal flying zone
Saludos
Gary Gower
701 912S
flying from 5,029 ft ASL strip.
--- On Thu, 4/29/10, Chuck Deiterich <cffd(at)pgrb.com> wrote:
Date: Thursday, April 29, 2010, 9:15 PM
Having Fun,
Chuck D.
N701TX
ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith701801-List
et=_blank>http://forums.matronics.com
ronlee
Posted: Tue May 04, 2010 9:03 am Post subject: Re: High and Slow |
I live in Southern AZ where the density altitude gets quite high. I have a Rotax 100 HP engine which handles the altitude well. What I noticed about the 701 is at about 9500 MSL the angle of attack gets quite pronounced. I think at that point the air starts going through the slats which causes quite a drag. My 701 handles the altitude better with the slats removed and vortex generators instead of slats, considerably less angle of attack up there..
_________________ Ron Lee
Tucson, Arizona |
randy(at)rjhebertassoc.co Guest
Posted: Tue May 04, 2010 9:53 am Post subject: High and Slow |
Ron
I read earlier threads on the slats vs. vgs and was wondering. Have you
removed the slat brackets or did you not build them when you were building
your wings?
Randall J Hebert
N7701P
Almost Finished, Yea right
