Europa motorglider as a tug?
rparigor(at)suffolk.lib.n
PostPosted: Tue Jan 10, 2006 11:03 am    Post subject: Europa motorglider as a tug? Reply with quote
I was reading on a Flight test of a Diamond HK 36 Super Dimona with a Rotax 914.
Literature states a 27 to 1 L/D
Article says it can tow a 1323 pound glider provided you keep gross weight of Diamond
below 1587 pounds.
If anyone wants, I can E-Mail you a 3 Meg PDF with article.
Ron Parigoris
Kevin Klinefelter
PostPosted: Wed Jan 11, 2006 5:30 am    Post subject: Europa motorglider as a tug? Reply with quote
The only problem is your Special Aiewothiness, Experimental aircraft
can't be used for glider towing.
Kevin
Europa XS, Mono Wheel N211KA
Intercooled 914, Airmaster Prop
