wdaniell(at)etb.net.co Guest
Posted: Mon May 03, 2010 5:17 am Post subject: Firewall |
Morning
Along similar lines to kevin's email has anyone used insulating material
for the firewall and if so, what sort and how much?
Will
Bogota
Kevin Klinefelter wrote:
Gidday Tony,
I have a similar installation on a monowheel and 6' worked for me.
Kevin
jimpuglise(at)comcast.net Guest
Posted: Mon May 03, 2010 5:58 am Post subject: Firewall |
AS markets a stainless steel firewall kit. In it they give you about a square yard of SS sandwich material and a tube of adhesive. You first cut patterns from cardboard, then cut the SS material with scissors, then use the adhesive to bond it to the firewall. It is actually about a 2 hour job and quite easy. However, there is a "gotcha." Be very careful of the SS material once you have cut it. It is VERY SHARP and will cut your hands to ribbons if you are not careful.
Jim Puglise A-283
Posted: Tue May 04, 2010 6:20 am Post subject: Firewall |
thanks Jim
jimpuglise(at)comcast.net (jimpuglise(at)comcast.net) wrote: [quote] p { margin: 0; }
Jim Puglise A-283
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
| [b]
