Mike Whisky
Posted: Sun May 09, 2010 8:00 am Post subject: Speaker in overhead console |
Hi there,
did anyone install a speaker in the overhead console, and do you know if there is anything to be aware of in terms of distance to the outside mounted GPS antenna, or the magnetometer cables passing by form the back?
Thanks Michael
_________________ RV-10 builder (flying)
#511 |
Posted: Sun May 09, 2010 8:31 am Post subject: Speaker in overhead console |
Michael Wellenzohn wrote:
Hi there,
I'm not .... you should be wearing a headset to protect your hearing,
making a speaker dead weight.
| Quote: | and do you know if there is anything to be aware of in terms of distance to the outside mounted GPS antenna, or the magnetometer cables passing by form the back?
Neither should be an issue ...... providing you use shielded cable and
terminate the shield properly.
Just my 2 pennies.
Linn
AirMike
Posted: Sun May 16, 2010 10:13 am Post subject: Speaker in overhead console |
I used the right back seat armrest area. It is easy to hear an reverberates in the cabin. Also easy to wire and repair in this area.
I think that you have to check the impedance to match the output.
Just remember magnets
_________________ See you OSH '18
Q/B - sold. |
