albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Sun May 09, 2010 3:16 pm Post subject: 912 installation |
Hi guys,
Just wondering if someone could share some pictures of their 912 installation. How does the cg work out. What size of prop? How far to the mounting face of the prop flange from the existing rear lord mounts? How much clearance to your tail boom and your flaps? Are you running a prop extension?
Tony
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Tue May 11, 2010 6:37 am Post subject: Re: 912 installation |
I can't answer all your questions at the moment but here's a few pictures.
http://www.ill-eagleaviation.com/EngineInstallation.htm
68" 3 blade Warp, 4" extension from Saber. I don't remember the measurement but there's plenty of boom clearance for a 70" prop.
Seems like John H. had a 72" Warp on for a while. Johns is a Mark 3 while mine is a Mark 3 Xtra.
_________________ Scott
www.ill-EagleAviation.com
do not archive |
Posted: Tue May 11, 2010 12:12 pm Post subject: 912 installation |
Scott
Scott/Gang:
I had 3/4" prop tip to boom clearance running the 72" WD.
Running a 71" now.
Main thing I take into consideration is to get the engine as low in the
mount as I can and still maintain sufficient clearance between the oil
return banjo fitting and the root tube of the airframe.
CG is not a problem.
Recently replaced the 12 lb Maule Tundra Tailwheel with a 6 lb Maule solid
rubber tailwheel. Did not do a weight and balance, but there was no
significant difference in the handling of the mkIII between the two
configurations. Biggest difference was transmission of rough field and
pavement cracks between the 6" solid and the 8" pneumatic tailwheels.
john hauck
_________________ John Hauck
Titus, Alabama |
capedavis(at)yahoo.com Guest
Posted: Tue May 11, 2010 3:32 pm Post subject: 912 installation |
John , just my wondering mind . Why the change havent you been using the 12 lb for a while successfully? just better weight?
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Sent: Tue, May 11, 2010 11:09:31 AM
Subject: Re: Re: 912 installation
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Scott
Scott/Gang:
Running a 71" now.
john hauck
mkIII[b]
Posted: Tue May 11, 2010 3:39 pm Post subject: 912 installation |
Chris Davis
Chris D/Gang:
I have flown the Maule 8" Tundra Tailwheel for six years. Two reasons I changed back to the 6" solid Maule:
-I wore out the bearings, pivot and wheel, in the 8".
-Thought maybe...I could get a little better cruise with the much smaller 6".
Results after the change - NONE.
Like I have advocated for many years, Kolbs have very wide CG ranges. Sometimes numbers are not quite honest. Not telling anyone to do anything other than what the Kolb Factory plans and instruction indicate for building and flying Kolb aircraft, but I find them much better performers in the air than on paper.
john hauck
Titus, Alabama |
albertakolbmk3
Posted: Tue May 11, 2010 6:22 pm Post subject: Re: 912 installation |
Thanks for the info and pics. What is your measurement from the rear lord mount holes to the face of the prop flange. Just looking for a measurement so I know how far back to mount it on the lord mounts.
Tony
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
albertakolbmk3
Posted: Thu May 13, 2010 3:18 pm Post subject: Re: 912 installation |
Could someone supply me with a measurement from the rear lord to the prop side of the prop flange of a 912 installation? It would be greatly appreciated!
Tony
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
