Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Fri May 14, 2010 11:32 am Post subject: 914 coolant temp |
Greetings,
The Rorax Corp insists on a coolant temp reading and suggests I believe the horizontal section of tubing exiting the reservoir (in amongst a sea of various components – and a real hardship to acquiesce.
On the other hand, there’s a kind open section vertical down towards the rad, which tempts as an alternative. Methinks there’s not much difference in the temps twixt one and t’other. It might lose a degree or two en route.
Has someone pronounced on this?
Thanks, Ferg [quote][b]
rampil
Posted: Fri May 14, 2010 12:05 pm Post subject: Re: 914 coolant temp |
Hi Ferg,
Actually, it is Rotax's intent that airframe manufacturers measure the
reservoir temp, not individual builders. The idea is to be absolutely sure
that the engine cooling system never allows the coolant to rise to
a temp which would ruin (anneal) the cylinder heads!
Of course, since Europa never did this test, it is up to you.
On the 912s, like mine, it was the paragon of simplicity to cut the
rubber coolant hose about two inches from the reservoir outlet
and use the Lockwood-supplied t-splice to place a thermistor in the
coolant stream.
The hottest common point in the coolant system is the reservoir, so
your measurement point must be as close as possible! A more
accurate system would put a thermistor in the coolant drain line from
each cylinder, but lets not go crazy here
paul.the.aviator(at)gmail Guest
Posted: Fri May 14, 2010 1:15 pm Post subject: 914 coolant temp |
Hi All,
I recently replaced the coolant hoses on my engine so while I had them all off I put a thermister in the reservoir. To do this I needed to TIG weld on a patch of aluminum to make it thick enough so I could put a thread in it for the temperature sensor.
To be honest, unless you have a particular reason to be pulling it apart using the use the Lockwood-supplied t-splice is much easier.
General question to the forum. I have often wondered if the heads got annealed if it would be practical to have them heat treated. I would assume that the value guide inserts and the seats would have to be removed and re installed after treatment.
Thoughts anyone ?
Paul
rlborger(at)mac.com Guest
Posted: Fri May 14, 2010 5:39 pm Post subject: 914 coolant temp |
| Quote: | Paul,
Unfortunately, the answer is no.
Go to Europa Owners photo gallery, page 2 and select the Lockwood School album. Go to page two of that album, Picture DSCN5124 and SDCN5125 to see what happens when you anneal one of the heads. It almost always means a new head and cylinder because you probably won't know it happened till the head bolts won't stay tight and the damage has been done by the combustion gasses.
Best regards,
Bob Borger
On Friday, May 14, 2010, at 04:14PM, "Paul McAllister" <paul.the.aviator(at)gmail.com> wrote:
Hi All,
Thoughts anyone ?
Paul
