AeroElectric-List Digest: 13 Msgs - 04/27/06
tlamp(at)genesishcs.org
PostPosted: Fri Apr 28, 2006 3:27 am    Post subject: AeroElectric-List Digest: 13 Msgs - 04/27/06 Reply with quote
Joe here is a picture of my install.
http://home.columbus.rr.com/tlamp/mvc-398f.jpg
and my entire construction page of the Long EZ at:
http://home.columbus.rr.com/tlamp/planpics.htm
I'm sure you have seen this type before, it has the typical microswitch
located behind the latch.
I think it would be better if I also had a magnetic switch inline to also
verify that the canopy is shut, as the latch can be locked and the canopy
not captured. It is pretty obvious if that happens, but it would be a safer
installation.
Terry Lamp
Long EZ N977JT
Ohio
________________________________ Message 5
_____________________________________
Time: 09:24:26 AM PST US
Subject: Canopy Latched Sensor
I'm looking for a better way to implement the canopy unlatched warning
system on a Long-EZ. The standard method is to use a small microswitch
that responds to "canopy latched". (This is not the same as "canopy
closed", which would be easy enough to implement but I want a "latched"
indication.)
Here's an illustration of the standard system:
http://users.lewiston.com/hth/jd/CanopyLockMicroswitch.jpg
When the canopy locking handle is pushed forward (left in the image) far
enough to latch the canopy locking mechanism, the head of the screw on
the handle (at the right in the image) fits in the hole on the latch and
actives the microswitch through its (specially bent) lever.
I'm not happy with the microswitch as it doesn't hold up well under use
and wonder if any Aeroelectric Connection readers can come up with a
better idea. I've searched for optical interrupters but can't find one
with a gap large enough for the head of the relatively large #10 screw.
I'm not familiar with any specific reflective-type optical sensors but
I'm guessing that would be the way to go.
Any ideas?
Joe
Long-EZ 821RP
Lewiston, ID
*****************Confidentiality Notice:******************************
The information contained in this e-mail message, including any
attachments, is intended only for use of the individual or entity
named above (addressee). This e-mail may contain information
that is privileged, confidential and/or otherwise exempt from
disclosure under applicable law. If the reader of this message is
not the intended recipient, any disclosure, dissemination,
distribution, copying or other use of the communication or its
substance is prohibited. If you have received this e-mail in error,
please reply to this e-mail indicating you are not the intended
recipient and immediately destroy all copies of this e-mail. Receipt
by anyone other than the intended recipient is not a waiver of any
privileged information.
echristley(at)nc.rr.com
PostPosted: Fri Apr 28, 2006 5:09 am    Post subject: AeroElectric-List Digest: 13 Msgs - 04/27/06 Reply with quote
AeroElectric-List Digest Server wrote:
________________________________ Message 8 _____________________________________
Time: 03:22:31 PM PST US
Subject: Re: Canopy Latched Sensor
Thanks, Dave but the metal-to-metal contact isn't reliable. The screw
head fits loosely inside the hole in the latch and the screw's grip
doesn't necessarily make solid contact with the edge of the .020" SS
latch. And there's no pressure on the "contacts".
Still looking for an optical solution ...
Make a "washer" from the .020" SS, one that has a long tab coming out
one side. Put the tab under the screwhead and arrange it so that the
tab interrupts the optical sensor.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o www.ernest.isa-geek.org |
jdubner(at)yahoo.com
PostPosted: Fri Apr 28, 2006 2:27 pm    Post subject: AeroElectric-List Digest: 13 Msgs - 04/27/06 Reply with quote
There isn't enough clearance for a tab, long or short, coming out one
side as the head of the screw is nearly in contact with the latching
mechanism. When latched, the head actually passes through the hole in
the latch but "enroute" to latching, it drags across the surface of the
latch mechanism until it "drops into" the hole. The latching mechanism
is "springy" SS (.020").
I've received some good ideas but what I really want is an optical
solution, with no metal-to-metal contact.
Apparently an optical interrupter approach is out because of the
clearance involved (the gap is far too tiny for the head of the #10
screw).
But what about a reflective optical sensor? It would mount on the
inside of the hinged door (which is open in the photo) and see nothing
under unlatched conditions. When the canopy is latched, the head of the
screw would reflect light and activate the sensor.
Has anyone done this? I see lots of datasheets for reflective optical
sensors but I don't know specifically which ones are readily available,
inexpensive, long focal length, useful and stable output level, etc.
Does anyone have real-world experience with one and can recommend a
specific part number?
Joe
mprather(at)spro.net
PostPosted: Fri Apr 28, 2006 3:59 pm    Post subject: AeroElectric-List Digest: 13 Msgs - 04/27/06 Reply with quote
I found that digikey has a large variety of slot type optical switches for
reasonable prices. So far, it seems that all of them would require just a
tiny bit of glue logic to make them work.
Mechanically, instead of configuring the switch so that the screw head
interrupts the LED beam, design a lever arrangement which causes a flag to
be actuated when the screw head is in position.
Attempt at a picture which might be worth a few hundred words:
http://www.webpak.net/~mprather/Share/switch.jpg
When the screw head is in the latched position, the flag is moved such
that light passing between trasmitter and receiver are interrupted. Drawn
in the unlatched position.
Matt-
> <echristley(at)nc.rr.com>
screw).
Joe
