sidsel.svein(at)oslo.onli Guest
				 Posted: Thu May 20, 2010 4:48 am    Post subject: SV: Kill Switch and External Power Receptacle |
				Tony,
 Unless you expect to have a centre of gravity-problem, I would not place the
 battery further back than in the baggage bay.  Easier access, and less cable
 weight.  It is nice to be able to put some baggage back there without
 worrying about CoG.
 I have a manual master switch behind the passenger seat head rest (purchased
 in a marine boat store), which kills all but trim and stall warner.
 For charging and jumper cables( to start by an external battery), I have a
 plug receptacle inside a small hatch just aft of the right side wing (just
 aft of the flap trailing edge).  This has some advantages vs. taking the
 cables in through an open door:
 - You can charge with the airplane locked.
 - If you need jumper cables to start the engine, you can do so with the
 doors closed (no risk of a door flying open by the propeller wash).  A
 helper on the outside can pull out the jumper contact and close the small
 hatch.
 Svein
