MauleDriver(at)nc.rr.com Guest
Posted: Wed May 19, 2010 5:28 pm Post subject: Seat belt sources and finishing of hardpoint |
I have replicated the front seat hardpoints in the rear so all 4
shoulder belts will attach to the canopy top with single NAS 517-5-9 bolts.
(I did not do the AMSAFE installation required for their inertial
reels. I did dig out the hole from the inside, scarfed the outer
surface and built up the hardpoint with layers of cloth and filled rest
of thickness with flox)
Question 1: I have a nice tan/brown Flightline interior and would like
to matching belts - any suggestions on sources? The Vans belts would be
fine if available in the right color.
Question 2: I want to glass the bolts into place but I'm worried if I
do that, will mounting the seatbelt fracture the glass? Or is the bolt
being left flush and uncovered? What have others done? How has it worked?
Thanks.
Bill "Jumping around from fiberglass task to FG task trying to figure
out how to get to paint" Watson
Jim Berry
Posted: Wed May 19, 2010 6:54 pm Post subject: Re: Seat belt sources and finishing of hardpoint |
Bill,
I have the same interior from Flightline. The Hooker belts are a very close color match. Can't help you with question 2.
Jim Berry
40482
N15JB
Lew Gallagher
Posted: Wed May 19, 2010 7:07 pm Post subject: Seat belt sources and finishing of hardpoint |
Hey Bill,
Question #2. I cut a slot in the head, imbeded a pop rivet stem in it to
keep it from turning, and glassed it over -- got the idea here -- and it is
still invisible from the outside, no cracks. And I can't imagine needing to
access it unless something really bad happened.
Wes has finished his fly-off time and is REALLY turning up the heat to get
me to fly with him. Maybe if you came down and flew with him, I'd get a
break!
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
