edgraydallas
				 Posted: Mon May 24, 2010 6:54 pm    Post subject: Kitfox-List Digest: 8 Msgs - 05/23/10 |
				Another solution to strut fairings--If you have a metal brake use the .018
 leading edge aluminum from acs which comes in 12 foot rolls.  Rip each strip
 into 6" strips, about 4 feet long, one for each side of the jury strut.
 Bend them into a 40 degree included angle (^) shape and cement them (scuff
 aluminum with 80 grit first) to struts at tangent point with epoxy.  They
 can be covered with cloth or painted.  This weighs 4 lbs total for all 4
 struts.  How much does the Kitfox fairings and the Lowes foam weigh for the
 entire 36 feet?  Using the wood or foam I would worry about trapped moisture
 next to the strut.  Comments?  PS Aluminum tape wrapped over the front will
 secure them if you don't trust the cement.
 Ed Gray, dallas, KFII 582 flying now with model 4 vertical tail and Mod 4
 building and looking for a 912S or maybe the Eggenfellner Honda  do not
 archive
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
