dutrac
Posted: Sun May 23, 2010 10:55 pm Post subject: Kolb MKII |
Hi All, Another question... What is it that makes a MKIII faster and able to carry more weight than the MKII? Is there any chance you can beef up a MKII?
Jason Omelchuck
Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
Posted: Mon May 24, 2010 9:59 am Post subject: Re: Kolb MKII |
Below are the things I think I know, it is possible I am full of something other than correct information.
The MKIII is faster because people put larger engines on them
MKIII has 6" spars, tail boom and MKII has 5" spars, tail boom
I think thicker steel is used on the motor mount tube
I dont know about the number of ribs in the wing or thickness of material
I dont know about the thickness of steel in the landing gear area
I dont think it would be possible to upgrade all the above.
Jason
| dutrac wrote: | | Hi All, Another question... What is it that makes a MKIII faster and able to carry more weight than the MKII? Is there any chance you can beef up a MKII? |
elleryweld(at)aol.com Guest
Posted: Mon May 24, 2010 5:46 pm Post subject: Kolb MKII |
Success comes in Cans not Cants
Ellery Batchelder Jr.
radiobluebook(at)gmail.co Guest
Posted: Mon May 24, 2010 7:39 pm Post subject: Kolb MKII |
Thanks for the update Jason. I believe you are right in that it probably isn't possible to upgrade any of these things.
On Mon, May 24, 2010 at 12:59 PM, Jason Omelchuck <jason(at)trek-tech.com (jason(at)trek-tech.com)> wrote:
[quote]--> Kolb-List message posted by: "Jason Omelchuck" <jason(at)trek-tech.com (jason(at)trek-tech.com)>
Jason
http://forums.matronics.com/viewtopic.php?p=298735#298735
le, List Admin.
Posted: Tue May 25, 2010 9:52 am Post subject: Kolb MKII |
> Hi All, Another question... What is it that makes a MKIII faster and able to carry more >weight than the MKII? Is there any chance you can beef up a MKII?
Dutrak, (is that your name??)
| Quote: | MKIII has 6" spars, tail boom and MKII has 5" spars, tail boom
Jason
The MkIII is a significant change from the MkII. With it's 6" main fuselage tube and 6" wing spars, it is quite a bit different than the MkII's 5" tubes.
Beefing a MkII up, or converting a MkII into a MkIII is no simple task!!! I mean......it's not easy like converting a MkIII Classic into a MkIII Xtra!! (LOL)
Mike Welch
MkIII CX
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. [quote][b]
Posted: Tue May 25, 2010 10:40 am Post subject: Kolb MKII |
Hi Mike,
Thanks for the input. It sounds like I won't be upgrading anytime soon.
Sincerely,
Duane
On Tue, May 25, 2010 at 12:39 PM, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
| Quote: | > Hi All, Another question... What is it that makes a MKIII faster and able to carry more >weight than the MKII? Is there any chance you can beef up a MKII?
Jason
Mike Welch
MkIII CX
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. | Quote: |
customersupport(at)tnkolb Guest
Posted: Thu May 27, 2010 8:24 am Post subject: Kolb MKII |
Excellent reply there Mike.I did know of a guy that installed a 912S on an older MII.Adriel Heisey from out in Fort Defiance AZ installed a 912S on his MII several years ago.I know he did several mods to make it work.
Travis
Kolb CO.
Posted: Thu May 27, 2010 8:56 am Post subject: Kolb MKII |
Travis/Gang:
Let me help out a little.
Adriel had a Twin Star, was looking for reliability over the 503 more so than performance, based on his professional aerial photography work and the environment in which he flew.
The Twin Star was designed for the Rotax 447 40 hp engine.
The MKII is basically a Twin Star with an enclosed cockpit, if I understand correctly.
_________________ John Hauck
Titus, Alabama |
