Tim Olson
Posted: Mon May 24, 2010 1:05 pm Post subject: Front tire make |
Does anyone remember what front tire make came with
the kit? I've been happy with the Desser HP retreads
on the mains, and my nose tire is going strong, but I
want to buy a spare. I figure since it's worked good
so far I may just buy the same thing again.
Tim Olson - RV-10 N104CD
rv10rob(at)gmail.com Guest
Posted: Mon May 24, 2010 1:34 pm Post subject: Front tire make |
My kit came with "Aero Classic" tires, both nose and mains.
-Rob
On Mon, May 24, 2010 at 2:05 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Tim Olson - RV-10s List Features Navigator to browse
s.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Mon May 24, 2010 1:38 pm Post subject: Front tire make |
Aero-Classic
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Tim Olson
Posted: Mon May 24, 2010 4:43 pm Post subject: Front tire make |
Thanks guys.
On May 24, 2010, at 4:27 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]My kit came with "Aero Classic" tires, both nose and mains.
-Rob
On Mon, May 24, 2010 at 2:05 PM, Tim Olson <[url=mailto:Tim(at)myrv10.com]Tim(at)myrv10.com (Tim(at)myrv10.com)[/url]> wrote:
Rob Kochman
Tim Olson
Posted: Mon May 24, 2010 6:40 pm Post subject: Front tire make |
You don't happen to remember if they're the Aero-classic
"Vintage" 6-ply or other, do you? I see the Vintage
has the tread pattern like mine, whereas the
6-ply "Light Sport" is way cheaper but doesn't have the
same tread. I figure the 500-6 6-ply LSA tire
would probably be ok on the nose, considering it's
for the mains on LSA's, just like Van's does with the
10....the nose tire is the same as the 2-place RV's
mains. I'm not sure if Van's consistently sells the
same model of tire through all delivery dates, but the
LSA is $37 and the Vintage is $73 from Desser...which is
where I've always got my tires. Van's sells one
in the 50's but doesn't specify which one.
Seano wrote:
Aero-Classic
ricksked(at)cox.net Guest
Posted: Mon May 24, 2010 7:03 pm Post subject: Front tire make |
Lol.....Vans supplied them....think "Dutch" and there you will find
the answers you seek grasshopper!!!
Rick
Seano wrote:
> Aero-Classic
Strasnuts
Posted: Mon May 24, 2010 7:09 pm Post subject: Front tire make |
Mine say type III 6 ply.
Seano wrote:
> Aero-Classic
780 Hours
Tim Olson
Posted: Mon May 24, 2010 7:23 pm Post subject: Front tire make |
Tha's what has me so confused...I can't believe they's splurge
on the 'spensive one.
Rick wrote:
Lol.....Vans supplied them....think "Dutch" and there you will find the
Rick
> do not archive
> Seano wrote:
>> Aero-Classic
Kelly McMullen
Posted: Mon May 24, 2010 7:29 pm Post subject: Front tire make |
I'm surprised you would have any need for a nose tire. They usually
last 2-3 times as long as mains. In 12 years of flying my Mooney, I've
replaced nose tire 1 time, on 3rd set of mains.
Seano wrote:
> Aero-Classic
A&P/IA, EAA Tech Counselor
KCHD |
Tim Olson
Posted: Mon May 24, 2010 8:09 pm Post subject: Front tire make |
I don't need it yet...it could go another couple hundred hours if I do
well. But as the center is wearing I'm going to keep it on hand this
summer in case it gets down there a ways, and then I'm going to
replace it early brefore my next out-of-USA trip. My old will be a
good spare if I keep it in a big ziploc with low oxygen levels. I
like spares. So I'm guessing the nose tire wouldn't have a big
problem making 800-1000 hours. I'm getting about 300-400 per set of
mains so your estimate is about right. I just don't want to go
international on less-improved strips with tires that aren't as thick
as they could be.
> do not archive
> Seano wrote:
>> Aero-Classic
