clint_bazzill(at)hotmail. Guest
Posted: Sat Feb 20, 2010 10:47 am Post subject: New Start Up Procedures |
Hi all,
I know that some of you are using my old start up procedures on your 912's.
I am using a modified procedure that works great, as follows:
Ign A & B off.
Throttle full idle.
Pull choke (idle enrichment) and hold, crank enging for 3-5 seconds.
Keep chock(idle enrichment) out, open throttle about 1 1/4 turn on vernier throttle.
Ign A & B on, crank enging, will start immediately, release choke (idle enrichment) then adjust warm up RPM's.
By doing this, you bypass the retarded timing, 6 deg BTDC and rough starts. Great on min gear box wear.
Clint Bazzill
912ULS Model IV-1200 1500 hours.
Half Moon Bay, Calif
wingnut
Posted: Sat Feb 20, 2010 2:40 pm Post subject: Re: New Start Up Procedures |
Boy. I wish my Kitfox started that easily. I'm working on adding a fuel primer to mine. She can be a real bitch some days.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Posted: Sat Feb 20, 2010 3:50 pm Post subject: New Start Up Procedures |
Try this method, make sure your engine is at full idle or enrichment will not work, or not enough to get it started.
Clint
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Sun Feb 21, 2010 5:47 am Post subject: Re: New Start Up Procedures |
Anyone have any great starting tips for a 582? Mine can be a real pain if the temps get below about 60.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Tom Jones
Posted: Sun Feb 21, 2010 6:40 am Post subject: Re: New Start Up Procedures |
| WurlyBird wrote: | | Anyone have any great starting tips for a 582? Mine can be a real pain if the temps get below about 60. |
If the idle is set very high the enricher circuit (choke) in the carbs doesn't work. With the idle set at 2500 on my 503 it was almost impossible to start when the temp was below 30 F. I had to take the air filter off and prime it with a squirt bottle to start.
I finally broke down and installed a primer this winter. No matter how long it has set or how cold it is, it starts first blade with the primer.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
dave
Posted: Sun Feb 21, 2010 9:53 am Post subject: Re: New Start Up Procedures |
I was flying today -10C --
3 shots of primer and fires right up .
get ready with more primer shots until it warms a bit or use enricher .
I hand propped mine as my battery is 5 years old and does not give enough
rpm to fire the ducati ignition - you need about 275 rpm min to get a fire.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
WurlyBird
Posted: Sun Feb 21, 2010 3:28 pm Post subject: Re: New Start Up Procedures |
With the throttle all the way out it will idle a little below 2000 which is way lower then I manually set idle, about 2600-3000. I may just have to look into a primer. When one was not installed when I bought the plane I guess I just figured it wasn't needed on this engine. Probably has more to do with the fact that it was built in South Florida, huh?
Fox5flyer Guest
Posted: Sun Feb 21, 2010 5:13 pm Post subject: New Start Up Procedures |
Exactly, James. The farther north the more you need a primer. Up here in
northern Michigan it's a must. If you're jetted right and get the hang of a
primer it'll start almost immediately each time no matter how cold. I've
often wondered why they aren't used on 912x , or are they.
Deke
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Sun Feb 21, 2010 7:17 pm Post subject: Re: New Start Up Procedures |
I don't have a primer on my 912. I haven't had a situation where I needed one to start this winter. Having a good, fully charged, battery helps, too.
(I've put on over 20 hours of ski flying, so far this winter with many cold starts.)
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
Guy Buchanan
Posted: Mon Feb 22, 2010 10:28 am Post subject: New Start Up Procedures |
At 03:28 PM 2/21/2010, you wrote:
| Quote: | With the throttle all the way out it will idle a little below 2000
You guys must not be running clutches. I idle at 1500 and have no
problem starting at any temperature the battery will support. (Down
to about 25F here in sunny SoCal.) I use the standard choke.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
Jeffrey Dill
Joined: 23 Jul 2007 Posts: 52 Location: Pleasant view, TN
Posted: Wed May 26, 2010 3:45 pm Post subject: Re: New Start Up Procedures |
With engine not running, I had fuel leaking from one carb on my 503. Spent 2 hours trouble-shooting. It turned out to be running in from the primer line. I think my first move will be to remove the primer. Should I just cap the points where the lines entered the carburators?
_________________ Jeff Dill
Model 2 |
