Any ideas on two minute delayed off
rparigoris
PostPosted: Wed May 26, 2010 8:43 pm    Post subject: Any ideas on two minute delayed off Reply with quote
Hi group.
Working on our gear warning system that needs to address needs for both powered flight and soaring flight we have designed one that does pretty good.
However we need a devise that can silence horn for approx. two minutes. In other words by switching a momentary switch, power to horn will be killed for approx. two minutes.
Needs to be able to handle 500 mA (at) 14.4 volts.
Something small and reliable like a delayed off relay, or??
Any ideas, and where to purchase would be appreciated.
Thx.
Ron Parigoris
PostPosted: Thu May 27, 2010 5:06 am    Post subject: Any ideas on two minute delayed off Reply with quote
At 11:43 PM 5/26/2010, you wrote:
<rparigor(at)suffolk.lib.ny.us>
Hi group.
both powered flight and soaring flight we have design one that does
pretty good.
minutes. In other words by switching a momentary switch power to
horn will be killed for two minutes.
Thx.
Ron Parigoris
You can build such a timer from Radio Shack parts.
What kind of 'horn' are we talking about. Solid
state, piezo electric or an electro-mechanical
buzzer?
Ed Anderson
PostPosted: Thu May 27, 2010 5:12 am    Post subject: Any ideas on two minute delayed off Reply with quote
Go to Google and typing in "555 timer relay" - you will find a lot of
circuits that would give you what you want and some units and kits as well.
Here's a couple of examples
http://www.aaroncake.net/circuits/relaytim.asp
http://www.hobbytron.net/R-UT-5.html
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://www.andersonee.com
http://www.dmack.net/mazda/index.html
http://www.flyrotary.com/
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.rotaryaviation.com/Rotorhead%20Truth.htm
Ed Anderson
Matthews, NC
eanderson@carolina.rr.com
jonlaury
PostPosted: Thu May 27, 2010 7:51 am    Post subject: Re: Any ideas on two minute delayed off Reply with quote
I've dealt with Carl's hobbies and they are first rate for service and suppport. I had to build a timer for another project and used the one in this link. I built it from a kit (educational and fun) or you can buy it assembled. This one has a toggle feature that seems like it would do what you want.
http://www.electronickits.com/kit/complete/elec/ck1614.htm?gclid=CNPA94rj2o4CFRcIYgodoEizAA
rparigoris
PostPosted: Thu May 27, 2010 9:09 am    Post subject: Any ideas on two minute delayed off Reply with quote
Hi Bob"You can build such a timer from Radio Shack parts. What kind of 'horn' are we talking about. Solid state, piezo electric or an electro-mechanical buzzer?"LOUD piezo. I was hoping to get away simple with something like an off the shelf reed switch/relay unit? Or perhaps 555 route is best?Ron Parigoris [quote][b]
PostPosted: Thu May 27, 2010 10:35 am    Post subject: Any ideas on two minute delayed off Reply with quote
At 12:05 PM 5/27/2010, you wrote:
Hi Bob
Yeah, simple SHORT delays are possible with some
rudimentary circuits using relays . . . but when
you need LONG delays, some electronics is in order.
Suggest:
http://aeroelectric.com/Pictures/Schematics/Piezo_Horn_Silence-Timer.pdf
You can try an aluminum electrolytic in the time delay
slot and see if it works well enough for you. A
tantalum per number suggested works best but they're
a bit pricy.
kuffel(at)cyberport.net
PostPosted: Thu May 27, 2010 1:34 pm    Post subject: Any ideas on two minute delayed off Reply with quote
The Carl's Electronics CANCK158 universal start stop timer kit has all the
pieces you need including the relay and push button.
See:
http://www.electronickits.com/kit/complete/timers/canck158.htm
At $15.95 for the kit ($18.95 assembled) it would be hard to find a better,
less expensive solution. Just run your buzzer wire through the Normally
Closed branch of the relay.
Tom Kuffel
