dreel(at)cox.net Guest
Posted: Tue Apr 25, 2006 6:51 am Post subject: Interpreting Aileron Position |
I have a feeling my ailerons are trying to tell me something significant about my heavy left wing condition but I'm having trouble getting it. So, here goes. In level flight, I'm applying full right manual aileron trim to stay level with the left tank empty. On the ground, I've established a visual picture of the neutral trail position of the ailerons relative to the wingtips by measurement with a digital level. So, when I look in the air, I expect to see the left aileron displaced down from neutral and the right aileron displaced up. What I actually see is the reverse situation. The left aileron is displaced up and the right down. What does this mean?
I've checked wing incidence, trimmed up the yaw, set the flaps to neutral trail, and found no vertical displacement errors in the ailerons themselves where they attach to the wing spar using the wing template. So, according to Van's instructions posted on their web site, I'm at the trailing edge squeezing stage. Could there be some other factor that would account for the unexpectedly reversed in-flight position? Something that should be corrected before squeezing? Or should I just follow Van's advice and squeeze til it flys level?
Dave Reel - RV8A
dbris200(at)sbcglobal.net Guest
Posted: Tue Apr 25, 2006 7:59 am Post subject: Interpreting Aileron Position |
Don't do anything until you try it without the manual trim connected
(assuming the spring system). The trim system can mask the symptoms and
could actually be causing the problem.
Dave -6 SoCal
EAA Technical Counselor
DAVID REEL wrote:
Dave Reel - RV8A
stein(at)steinair.com Guest
Posted: Tue Apr 25, 2006 8:53 am Post subject: Interpreting Aileron Position |
Is the ball centered or are you flying with the ball off center somewhat?
This is the 1st thing to look at with heavy wings. If you are skidding
through the air somewhat, that can cause a surprisingly heavy wing. This
can and is caused by either the Vertical Stab needing adjustment, or more
commonly the gear legs fairings being mis-aligned. If that isn't the cause,
then you need to get to "squeezing" the light wing down and start fixin. If
that doesn't work, then the only solution left is to remount the ailierons
with a new hinge and place them up or down as needed.
Stein.
[quote]--
dennis.glaeser(at)eds.com Guest
Posted: Tue Apr 25, 2006 9:11 am Post subject: Interpreting Aileron Position |
If the left tank is empty, then to compensate, the left aileron would be
UP to compensate. In essence, the left wing needs less lift - up
aileron - (less weight) and the right wing more lift - down aileron -
(more weight with the fuller tank). So what you are seeing is what I
would expect.
I'm not clear about what you mean by 'full right aileron trim' - which
way are you moving the trim lever?
I agree with Dave Bristol - disconnect the manual trim and fly before
doing anything.
Dennis Glaeser
RV7A
right down. What does this mean? I've checked wing incidence, trimmed up
level?
Dave Reel - RV8A
khorton01(at)rogers.com Guest
Posted: Tue Apr 25, 2006 9:45 am Post subject: Interpreting Aileron Position |
On 25 Apr 2006, at 10:51, DAVID REEL wrote:
flys level?
1. Disconnect the trim springs and try it.
2. Remove the gear leg fairings and fly it, to confirm they are not
3. Level the aircraft side-to-side on the ground, and be sure your
ball is centered. If not, slot the holes on the TC (or EFIS, or
where ever the ball is), and rotate it to center the ball. Then, in
flight, use rudder as required to center the ball. Add a rudder trim
tab if required.
4. Carefully inspect the aileron trailing edges. Are the trailing
edge radii and contours the same on each side?
5. How is the upper wing skin contour ahead of the ailerons? If you
lay a straight edge on the wing skin, is there a difference in
contour from one side to the other? If so, this could affect the air
pressure on top of the aileron, and cause an aileron deflection.
Keep us posted.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
phil(at)petrasoft.net Guest
Posted: Tue Apr 25, 2006 9:50 am Post subject: Interpreting Aileron Position |
My heavy left wing seems to be caused by a little twist in the flap, so
you might want to check that I also don't have much faith in either
digital levels or the wing template. Make sure the tooling holes in the
wing ribs and aileron ribs are lined up. That's the way we do it on the
-7's and since the wing is the same it should work on your -8 too.
And just in case nobody mentioned this... try it without the trim hooked
up.
If I had to guess I think the aileron is trying to tell you that your
airplane is straight and the aileron trim is off.
Godspeed,
Phil Birkelbach - Houston Texas
RV-7 N727WB
http://www.myrv7.com
DAVID REEL wrote:
Dave Reel - RV8A
martin(at)gbonline.com Guest
Posted: Tue Apr 25, 2006 7:00 pm Post subject: Interpreting Aileron Position |
Dave,
Six years ago when I first flew my RV8 I experienced a similar problem.
After trying every remedy under the sun, I finally noticed that the outer
aeleron hinge positioned the aeleron about 1/8 inch lower than the inboard
hinge next to the flap. I had tried all of the other remedies to no avail.
After many discussions with everybody who had an opinion, it was decided
that I was experiencing "flow separation" on that aeleron. I got a new
hinge from Vans and very carefully fitted it so that the top aeleron surface
was perfectly even with the wing trailing edge. this
corrected the problem and I have flown hands off ever since. I now have
1300 hours and still enjoy every minute.
Good luck,
Dick Martin
RV8 N233M
the fast one
Posted: Wed Apr 26, 2006 2:34 pm Post subject: Interpreting Aileron Position |
After digesting all the replies, for which I thank you all, I got this =
idea from Phil Birkelbachs. I have adjusted the ailerons so that they =
are both at the same angle of attack on the assumption that they would =
be equally balanced in flight. Right now, when one is lined up with =
it's flap, the other lines up with the other flap. Seeing that they are =
indicating a roll to the left by their in-flight position even though =
I'm applying considerable roll right stick input to stay level tells me =
they're not balanced in this position. What I should be doing is =
decreasing the angle of attack on the powerful aileron, the left one, =
and increasing the angle of attack of the right one to get an in-flight =
balance position with the ailerons closer to the known neutral in-trail =
position. This will look funny on the ground because they won't line up =
with the flaps but something I can't see or measure is changing the =
airflow each sees & I should adjust to that.
Is this reasonable? I think I'll just adjust one aileron or the other a =
little 'out of line' to see how this works.
Dave Reel - RV8A
Posted: Thu Apr 27, 2006 8:43 am Post subject: Interpreting Aileron Position |
On 26 Apr 2006, at 18:33, DAVID REEL wrote:
this =
they =
would =
they are =
though =
tells me =
one, =
flight =
trail =
line up =
other a =
If you are talking about adjusting the length of the various aileron
pushrods, as a way to fix your roll trim problem, I believe you are
wasting your time. If you have the aileron trim in neutral, and you
let go of the stick, the ailerons will move to the position that
balances the forces on the left and right ailerons. If you screw
around with the pushrods, you might move both ailerons up a bit, or
down a bit, but I don't believe you will make any significant
difference the relative positions between the two ailerona.
Go ahead, try it if you want. But don't be surprised if it doesn't
fix your problem.
The aileron positions are a symptom of the real problem. They are
not the problem. You need to find the underlying problem, rather
than trying to treat the symptoms.
Ottawa, Canada
bertrv6(at)highstream.net Guest
Posted: Sun May 07, 2006 3:19 pm Post subject: Interpreting Aileron Position |
Quoting Kevin Horton <khorton01(at)rogers.com>:
> this =
> they =
> would =
> they are =
> though =
> tells me =
> one, =
> flight =
> trail =
> line up =
> other a =
fix your problem.
Ottawa, Canada
Kevin:
My suggestion is try to align both ailerons, I know it was very difficult
for me to do, when I was finishing my Rv6a,,,It took a lot of time and trial
and error, but I was able top algin both ailerons, with the flaps..I do not know
if you meant that one both are align but one side, is different that
the other? how can that be, if you built according to plans?
I did have to add a shimm on one side,to match with the flaps, although
it was only about 1/8. I could have left it that way, but you know...is our
rv....
Just my nickel worth
Bert
rv6a
On my test 40 hrs.
Posted: Mon May 08, 2006 7:02 am Post subject: Interpreting Aileron Position |
I'm getting nearer the solution to trimming up my RV8A's roll tendencies.
After a long conversation with Rick McBride, who has an RV8 hangered near
me, I now believe that changing pushrod lengths in the aileron control
system will not affect roll tendency. It will just affect how closely to
the neutral trail position the ailerons balance in-flight. This affects
drag, but since the up (or down) force on both ailerons is the same,
otherwise they wouldn't balance, there cannot be any contribution to roll.
Somehow, in all the discussion of trailing edge squeezing, I forgot that you
can just make a temporary trim tab and try it. I was delaying making any
change because I thought of it as permanent. But, I went back to read Vans
instruction book & now am trying various lengths of trim tab. One useful
observation in the instructions was that unless the trim tab exceeds 6
inches in length, the rest of the airplane is not seriously out of trim. So
I tried a wedge 3" wide, 1/4" high, and 1.5 inches long. Voila! trim was
now within range of the manual trim system to correct. What a relief & how
much more enjoyable to fly with fingertip control. The aileron position in
flight still looks backward, as though it's trying to roll the airplane left
when in fact a right roll correction is being input by the trim tab, but I'm
much less worried about serious structural misalignment now so I've
relegated explaning that to the far back burner.
Dave Reel - RV8A
sbuc(at)hiwaay.net Guest
Posted: Mon May 08, 2006 8:08 am Post subject: Interpreting Aileron Position |
Dave, glad to hear you are getting the aileron trim sorted out.
I am curious about something; during our flight back from Sun-N-Fun, I
talked to a pilot flying near the Florida panhandle who had a new RV-8
"toy" and in the course of our chat we briefly discussed roll trim. Was
that you?
If in our area, don't hesitate to jump to north Alabama sometime and
share a fly-in breakfast with us.
Best regards,
Sam Buchanan
Tennessee Valley RV Builders Group
http://www.tvrvbg.org
DAVID REEL wrote:
Dave Reel - RV8A
michele.delsol(at)microsi Guest
Posted: Wed May 10, 2006 6:36 am Post subject: Interpreting Aileron Position |
A little late as I am catching up on my mail but have you checked your wings
for twist? If they are twisted ever so slightly in opposite directions, one
wing's twist will accentuate the other wing's twist then that may be the
problem.
Michele
RV8 - Fuselage
