		zwakie
				 Posted: Wed May 26, 2010 5:44 am    Post subject: Realistic price for 914F3? |
				Someone informed me about a Rotax 914F3 that will be coming up for sale in the near future.
 I was told that this fully certified engine:
 - currently runs on a certified airplane
 - will be taken off due to TBO coming up shortly (year of build: 1998)
 - is in perfect shiny state ("looks like brand new")
 - has 400 hours TT on the clock
 - will be delivered with all parts and documentation that you would get when buying a new 914F3
 - will receive a 600 hrs interval inspection and maintenance before it is being sold
 - has all SB's/TM's completed
 - has flown appr. 30 hours each year, without extended periods of non-running
 - has always been maintained according to Rotax maintenance schedules
 To me this sounds like a perfect opportunity to have a certified engine for a homebuilt. But.... since I have not built my Europa myself, I have no clue about prices of engines.
 I would therefore highly appreciate all input I can get from the Europa-community on the subject of price: what do you think would be a realistic price for this engine based on above description?
  _________________ Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR |
		zwakie
				 Posted: Sun May 30, 2010 1:03 am    Post subject: Re: Realistic price for 914F3? |
				Anyone out there who can give me some direction on this?
  	  | zwakie wrote: | 	 		  Someone informed me about a Rotax 914F3 that will be coming up for sale in the near future.
 I would therefore highly appreciate all input I can get from the Europa-community on the subject of price: what do you think would be a realistic price for this engine based on above description? |
		acrojim7534(at)YAHOO.COM Guest
				 Posted: Sun May 30, 2010 3:45 am    Post subject: Realistic price for 914F3? |
				I do not think that Rotax had any "certified" engines in 1998.... Check the serial number, if it has UL after the serial number then it is not certified...at least to my thinking....
  Here in the U.S. if you install a "certified" engine in a experimential airplane then the engine becomes a non certified engine..Or words to that effect.
  I know some of the 912 S series of engines installed in the Light Sport airplanes are certified, I have not seen any 914 engines installed in certified light sport airplanes.....
  In 1998 Rotax did not have any TBO's on their engines, sometime in the mid-2000 they started showing TBO on the light sport aircraft and I think all of the Light Sport a/c are equiped with the 912 S series of engines.
  These are my thoughts, as to your questions... I have operated a 914 since 2000 when I started flying a monowheel with a 914..At that time Rotax did  not have any certified engines..
  Jim Brown
  N398JB
 Sent: Sun, May 30, 2010 5:03:37 AM
 Subject: Re: Realistic price for 914F3?
 --> Europa-List message posted by: "zwakie" <mz(at)cariama.nl (mz(at)cariama.nl)>
 zwakie wrote:
  	  | Quote: | 	 		   Someone informed me about a Rotax 914F3 that will be coming up for sale in the near future.
 Marcel
 (Classic Tri-Gear PH-MZW - formerly G-BWON)
 Read this topic online  here:
 http://forums.matronics.com/viewtopic.php?p=299335#299335[b]
		rampil
				 Posted: Sun May 30, 2010 5:19 am    Post subject: Re: Realistic price for 914F3? |
				I believe the F models were indeed certificated, although I was unaware
 of a 914F.
 The Diamond Katana aircraft used a certificated 912 starting in about 1994
		rampil
				 Posted: Sun May 30, 2010 5:24 am    Post subject: Re: Realistic price for 914F3? |
				Just out of curiousity, what certified aircraft used this Rotax 914?
 A Stemme? A super Dimona?
 In the US at least, the certification status of an engine adds nothing
 to its value in homebuilt applications
		stranfaer(at)btinternet.c Guest
				 Posted: Sun May 30, 2010 8:37 am    Post subject: Realistic price for 914F3? |
				Marcel
 Second user engines are really difficult to value and its really what are
 you prepared to pay?
 However personally I would have thought that between £5K and £8  for what
 you have described, am sure that someone will chip in with either more or
 less of a figure, anyhow have chucked a stone in the pond so let's see where
 the ripples go?
 As far as I am aware certainly here in UK if you put a certified engine into
 a permit aircraft it then becomes non certified? Will have a great
 maintenance record though, probably better than most permit engines? A
 flying buddy of mine replaced a 912UL from his certified aircraft with a
 replacement exchange engine from Austria/Germany and they were credited less
 than £3K for it (had done 800Hrs)!
 rgds
 Dave Joyce (The other one, former co owner of G-BWON)
 Sent to you from David Joyce
 www.eastmidsspas.com
				 Posted: Sun May 30, 2010 8:48 am    Post subject: Realistic price for 914F3? |
				On 05/30/2010 03:24 PM, rampil wrote:
 It will devaluate the engine, as the maintenance of homebuilt aircraft
 is not considered "certified maintenance", hence the engine will loose
 its certification.
 There is no technical difference between a certified Rotax and a
 non-certified Rotax.
 Frans
		tonyrenshaw268(at)gmail.c Guest
				 Posted: Sun May 30, 2010 9:19 am    Post subject: Realistic price for 914F3? |
				Hello Jim,
 I am an Australian builder about to install a 914. Could you pls tell
 Me if yours uses a standard Europa fuel supply setup? If u built your a/c
 And have any specific advice about this engine install
 I am like a dry sponge at the moment.
 Reg
 Tony Renshaw
 Sydney Aussie
 On 30/05/2010, at 9:44 PM, Jim Brown <acrojim7534(at)YAHOO.COM (acrojim7534(at)YAHOO.COM)> wrote:
 [quote]I do not think that Rotax had any "certified" engines in 1998.... Check the serial number, if it has UL after the serial number then it is not certified...at least to my thinking....
  Jim Brown
  N398JB
 To: [url=mailto:europa-list(at)matronics.com]europa-list(at)matronics.com (europa-list(at)matronics.com)[/url]
 --> Europa-List message posted by: "zwakie" <[url=mailto:mz(at)cariama.nl]mz(at)cariama.nl (mz(at)cariama.nl)[/url]>
 Marcel
            	  | Quote: | 	 		  [b]
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
		pete(at)lawless.info Guest
				 Posted: Sun May 30, 2010 11:34 am    Post subject: Realistic price for 914F3? |
				Just a thought if it was certified and the aeroplane used for training in
 the UK then it will have been run on AVGAS 100LL for its entire life.  Not
 good!
 Pete
		zwakie
				 Posted: Sun May 30, 2010 11:17 pm    Post subject: Re: Realistic price for 914F3? |
				Thanks to all for the input and 'warnings'.
 I am aware that the main benefit of acquiring a certificated engine are the availability of maintenance logs. I hadn't yet thought about the engine loosing is certification status, but seems quite logical (and even obvious) to me.
 (at) rampil: Good guess, the engine coming up for sale is currently operated on a Super Dimona
 (at) David: Thanks for throwing that stone. I hope you are right, and others will throw a price-expectation in.
 (at) Pete: good point, something to look into, thanks!
 Maybe it's worthwhile if others can provide a realistic price for the 914UL version...
		DanBish
				 Posted: Mon May 31, 2010 8:19 am    Post subject: Re: Realistic price for 914F3? |
				I bought a new, in-the-crate, 914F in Jan of 2006 for $18k. At the time, they were going for around $30k but I totally discount the fact that it's certified for the earlier stated reason that in an experimental, it doesn't retain it's status.
 Granted, I got extremely lucky- this guy just happened to be retiring and was closing his shop and had 2 914's and 6 912's that he was selling off. He'd been doing contract work for the DOD on the Predator program. But even still, for a used one I don't think I'd pay more than $10k unless it was able to be verified that it was extremely low use.
 My 2 cents,
 Dan
		John Wighton
				 Posted: Tue Jun 01, 2010 3:51 am    Post subject: Re: Realistic price for 914F3? |
				Having had experience with Rotax engines ran on only Avgas 100LL l would estimate you have a high chance of big expenses well before TBO.  Hence price l would recommend is around €4000-4500.  Obviously check the compressions and analyse the oil/filter before committing.
		zwakie
				 Posted: Tue Jun 01, 2010 9:41 am    Post subject: Re: Realistic price for 914F3? |
				Thanks to all that gave advise and things to be careful about. One more question, if someone would be answer this one, I think I have some realistic ground to base my decision on:
 How would the price of an engine that has only run on AVGAS relate to one that only took unleaded fuel, is it in the region of 1/3rd, one half, 2/3rds?
		n100rh(at)sbcglobal.net Guest
				 Posted: Tue Jun 01, 2010 10:26 am    Post subject: Realistic price for 914F3? |
				Marcel,
 This most likely won't be of much help, but having said that...
 I have a brand new, still pickled 914 that was purchased from CPS in
 California 10/20/2004 that CPS says I should be asking $25,000 for OBO.
 I will be putting it and everything else back on Barnstormers web site
 in the next few days.
 Ralph
 On 6/1/2010 10:41 AM, zwakie wrote:
  Marcel
  http://forums.matronics.com/viewtopic.php?p=299588#299588
