davercook1501(at)yahoo.co Guest
n801bh(at)netzero.com Guest
Posted: Sat May 29, 2010 5:28 pm Post subject: Trouble with Altimeter |
If it is a Falcon one that's about 5 years old it is time to buy a new altimeter.
Ben Haas
N801BH
www.haaspowerair.com
altoq(at)cebridge.net Guest
kellemsm(at)yahoo.com Guest
Posted: Sat May 29, 2010 6:41 pm Post subject: Trouble with Altimeter |
Some do and some don't
Sent via BlackBerry by AT&T
rhdudley1(at)bellsouth.ne Guest
Posted: Sun May 30, 2010 4:59 am Post subject: Trouble with Altimeter |
At about five years, I found my Falcon altimeter showing about 3000 feet sitting in the hangar at field elevation of about 50 feet. It could not be re-adjusted and continued to climb sitting in the hangar. My solution was to replace it with a non-Falcon instrument at about 3X the cost.
Richard Dudey
Posted: Sun May 30, 2010 8:41 am Post subject: Trouble with Altimeter |
The expensive ones fail too. Mine did about 3-4 years ago. I was returning from a trip and descended to what my eyeballs thought was pattern altitude, checked the altimeter and it was showing 3,000' higher than my eyeballs. I tapped it and it unfroze, moved a bit, and stuck. I had it fixed (and re-calibrated) by a shop in San Antonio. Don't remember the name of the shop, but the cost was ~$100 and I had the altimeter back in a week.
If you look throught the RV-list archives (or the RV list Yeller Pages), you should be able to find the company.
Kyle Boatright
Posted: Tue Jun 01, 2010 7:14 pm Post subject: Trouble with Altimeter |
Went out to the airport today to blow out the static line and adjust the altimeter. It was back to normal.
Took a flight and it worked OK. Had some flutter to it though. Don't know about it's longevity.
David R. Cook
N815DC RV-6
Flying
To: rv-list(at)matronics.com
Sent: Mon, May 31, 2010 10:34:17 PM
Subject: Re: Trouble with Altimeter
Thanks for the replies. I will let you know the end result.
David R. Cook
N815DC RV-6
Flying
To: RV-List <rv-list(at)matronics.com>
Sent: Sat, May 29, 2010 8:37:40 PM
Subject: Trouble with Altimeter
Hi All
My altimeter just went crazy. Jumped in the ole 6 and spotted the altitude had gone up 300 feet. Reset to field elevation and the pressure reading was 28.7. I looked around an there was no hurricane in sight.
Any one have an explanation. The unit is only 3 years old from Vans. Do I just reset it or is there a problem?
Dave
David R. Cook
N815DC RV-6
Flying
Posted: Wed Jun 02, 2010 4:34 am Post subject: Trouble with Altimeter |
Maybe there's still some trapped water in the system???
Linn
david cook wrote: [quote] Went out to the airport today to blow out the static line and adjust the altimeter. It was back to normal.
David R. Cook
N815DC RV-6
Flying
From: david cook <davercook1501(at)yahoo.com> (davercook1501(at)yahoo.com)
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: Re: RV-List: Trouble with Altimeter
David R. Cook
N815DC RV-6
Flying
To: RV-List <rv-list(at)matronics.com> (rv-list(at)matronics.com)
Subject: RV-List: Trouble with Altimeter
Hi All
Dave
David R. Cook
N815DC RV-6
Flying
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
