jonlaury
Posted: Tue Jun 01, 2010 9:36 am Post subject: Long and short hot feeders |
I have used Littlefuse modular fuse holders to make up a fuse panel. This presents the problem of all the fuse holders having a short 6-10" wire to reach the bus.
Are they short enough to ignore (like the * denoted wires in the Z-figures) or are fuselinks appropriate here?
I also want to bring the battery bus up close to the fuse panel so that the batt bus fuses can be displayed in the panel. The # 12-14 hot feeder wire is about 24". Putting a mini-contactor at the battery end seems to defeat the purpose of the always-hot batt bus, but from previous kicks in my rear, I'm hesitant to say "fuselink" here.
But I guess I can't help myself!
I'm confused about where fuselinks are appropriate and where they aren't. It seems like a hot feeder is an appropriate place because I want the feeder hot and be able to handle inrushes without interruption. But if there's a dead short on it I want it to fail before all the arcing sets something on fire or melts adjacent infrastructure.
Posted: Tue Jun 01, 2010 11:02 am Post subject: Long and short hot feeders |
Why so long?
Quote: | Are they short enough to ignore (like the * denoted wires in the
Fusible links are recommended ONLY where depicted
on the z-figures. Check the archives for lots
of discussion.
I'm mystified as to the value in building a distribution
component that has so many crafted joints and detail
parts. Off-the-shelf fuse blocks were originally proposed
for their cost of ownership savings over the legacy
breaker panel configurations.
But it seems you're driving your parts count up
markedly along with $time$ invested to construct
and maintain it.
jonlaury
Posted: Tue Jun 01, 2010 1:29 pm Post subject: Re: Long and short hot feeders |
Bob,
Re length:
That's how far away my fuse panel is from the buss. Understand that the modular fuseholders are single fuse holders that you can clip together to make any size fuseholder you desire. You can fit more fuses in the same space as the off-the-shelf blocks.
see http://www.littelfuse.com/data/en/Data_Sheets/155_153PCMount.pdf
They allowed me to fit all my fuses into available space. I wanted to be able to see the panel because I intend to use the ATO fuses with a blown indicator light.
So yes, there are two additional crafted connections on the pigtail to the bus. And yes it's a lot more work to make a panel to accomodate the modular system. And yes, the modular cost savings over a pre-configured plug'n play panel is negligible. And yes none of this makes any sense, except that I like the look of the panel that I made.
So would fusible links be appropriate for the pigtails?
jonlaury
Posted: Tue Jun 01, 2010 2:08 pm Post subject: Re: Long and short hot feeders |
Bob,
In your FAQ on the AC, you say:
"Fusible links are used when you have a
single leadwire to protect where it is VERY unlikely that it will ever see a serious fault and/or
where the
ultimate in circuit reliablity is needed."
Additionaly you speak of using fusible links to "extend the bus..."
It seems that running a wire from the battery to a remote battery buss meets the fusible link appropriate useage you've discussed. But your caveat about not adding fusible links to Z-figures gives me pause. I'm not comfortable second guessing your expertise.
John
Posted: Tue Jun 01, 2010 3:37 pm Post subject: Long and short hot feeders |
At 05:08 PM 6/1/2010, you wrote:
Quote: |
Bob,
where the
Yes. In this regard, they are very much like
the ANL current limiters. Exceedingly robust
but weak link in the electron chain . . .
Quote: | Additionaly you speak of using fusible links to "extend the bus..."
but ONLY in the configuration depicted. This
is a special case for using a circuit breaker
upstream of a crowbar ov module when the bus
is a distribution point for fuses. If the
crowbar module is installed in an aircraft
with a classic breaker panel, then the "extended"
bus is not needed and the breaker gets installed
right next to its brothers and sisters.
If you have an array of fuses or breakers used
to distribute power in the aircraft, then the
BUS is located right at the upstream side of
that fuse or breaker. This is how you get the low
parts count and compact assembly. We don't
bring an array of wires off a bus to fuse(s)
or breaker(s) and hence to the protected loads.
If you're going to assemble your own fuse block,
then what you've proposed will FUNCTION as
advertised . . . but it's not something that
anyone in the business would recommend.
Quote: | It seems that running a wire from the battery to a remote battery
Absolutely not. Always hot wires are either
crew controlled -OR- protected at low levels
on the order of 7A fuse or 5A breaker. If
you are attaching wires to the battery and they
have lengths greater than the 6-inch rule of
thumb then the design goal for low magnitude
protection applies. In other words, a battery bus is
located next to the battery. Any other location
makes it something else.
Quote: | But your caveat about not adding fusible links to Z-figures gives
The wires you propose are simply wires. There is
no useful purpose in calling them or designing them
to be "fusible links". Wire it up and it WILL
function.
jonlaury
Posted: Tue Jun 01, 2010 9:43 pm Post subject: Re: Long and short hot feeders |
Aargh!
I hate arguing with common sense and good design when I've spent all that time making that cute little panel.
But your reasoning is hard to refute.
Honestly I got so caught up in making this cool fuse panel and getting 30 fuses in a tight pattern that I overlooked the fact that I was going to have a whole nest of hot wires to deal with.
Just have to get used to not being able to see my fuses and comfort myself with fewer parts count and fewer constructed joints. And ditto on the battery bus. It's moving back to the battery.
Again thanks for taking the time to explain all this. I makes it a little easier to throw that fuse panel into the trash.
John
Posted: Wed Jun 02, 2010 7:33 am Post subject: Long and short hot feeders |
At 12:43 AM 6/2/2010, you wrote:
Aargh!
You're not alone. EVERY finely tuned recipe for success was
preceded by many if not thousands of experiments that were
discarded.
Thomas Edison was often referred to as the "master experimenter"
in recognition of his patience and persistence in the conduct
of his craft. Charles Kettering, ditto.
I cannot begin to deduce the magnitude of my own efforts that
that ultimately went into the trash . . . the reason being
that those experiences were discarded both physically and
intellectually. But when the effort was successful, the
work product went into useful service and the recipe for
success went into the intellectual archives for future
reference.
I recall visiting an estate sale about 20 years ago that
included a lot of goodies from a ham radio operator that
had departed this earthly plane. While digging through a pile
of stuff, I was startled to see a familiar device. It was
a vacuum tube electronic code keyer that I built for another
ham perhaps 25 years earlier . . . I don't know how many times
it changed hands but it was still functional. Further, I
could still draw a schematic for the thing.
Good education is NEVER inexpensive in terms of $time$
and slips to schedule. But it seems to me that the most
"expensive" lessons are best retained. By having
this discussion on the List, we're reducing the investment
necessary for others to benefit from simple-ideas
that go into their own exploitation of the same recipe for
success. If it's any consolation, your loss contributes
to the gains of others . . . but only if it's shared.
I've often remarked to publishers of my articles that
they solicit articles on failures too. I always get a
reaction of surprise and perhaps dismay. I then explain
that it's often more useful to know what does not work
as things that do work. It's a prophylactic against repeating
the same failure over and over again.
Keep at it my friend and thanks for participating.
rckol
Posted: Thu Jun 03, 2010 1:21 pm Post subject: Re: Long and short hot feeders |
John,
It looks like you are going to change course here based on Bob's advice, so this information may not be needed but, I noticed yesterday that SteinAir is selling bus bar/terminal strips with 10 terminals each on them that could probably be used to feed your fuse holders, if they were located in close proximity to your fuse holders.
http://www.steinair.com/strips.htm
_________________ rck |
Posted: Thu Jun 03, 2010 5:50 pm Post subject: Long and short hot feeders |
At 04:21 PM 6/3/2010, you wrote:
Quote: |
John,
Hmmmm . . . I cannot imagine where those would
be used. Further, they feature non-locking, threaded
fasteners.
When such devices are called for in TC aircraft (rarely)
they look more like this . . .
http://aeroelectric.com/Pictures/Wiring_Technique/Terminal_Strip_Captive_Stud.jpg
Note the captive treaded studs with LOCKING hardware.
I need to go back and look up that installation in the wire
books. In the picture above we see a mix of wire guages
which makes me wonder if it's a ground bus. Otherwise,
one would be hard pressed to provide appropriate
fuse/breaker protection for the wires serviced by
the bus.
In any case, if one truly needs such a bus, then
drill and tap a copper bar for at least 8-32 (10-32
better) screws. Thread in from back side and captivate
screws to bus bar with JB weld under head of screws
and last few threads under head. Torque well.
Terminal faces on wires go right against the bar and
against each other on the stud side. Cap of with a flat
washer and well torqued locking nut. If you need to
insulate the assembly from ground, then some work on
a saw and drill press will carve out a piece of
phenolic, delrin, lexan or perhaps even some cutting board
stock.
jonlaury
Posted: Fri Jun 04, 2010 7:49 am Post subject: Re: Long and short hot feeders |
Rckol,
Thanks for the heads up.
But yes, now that I've gotten unstuck on my idea, light is streaming down from the heavens, angelic trumpets are sounding along with a chorus of Hosanna's and fuse blocks have acquired a golden glow.
All I had to do is let go of the idea of being able to see all my fuses.
Probably will do some sort of blown fuse indicator LED instead, but that's a project for after I'm airborne.
John
Do not Archive
mrspudandcompany(at)veriz Guest
Posted: Fri Jun 04, 2010 8:23 am Post subject: Long and short hot feeders |
John
And that is the "Hot Feeders Long and Short of it"
Do not Archive
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
3.39 KB |
Downloaded: |
510 Time(s) |
