kearney
Posted: Sun Jun 06, 2010 6:05 pm Post subject: Comm Antenna |
Hi
Thanks for all the info on comm antennas.
Checking out my planned placement, I realise that anyone accessing the baggage area coold accidently interfere with the antenna (luggage on ground etc). Not wanting to pull my floor pans or to install anything where it is inaccessible, I have decided to put one antenna in the tunnel just aft of the seats and off center (so it doesn't interfere with the control tubes). The other will go on the centerline in the empennage about 4' aft of the first.
In retrospect and given the comments from Kelly et al, I like the idea of having one antenna completely clear of wings, gear and steps. I really would like to avoid an antenna on top (other than the GPS puck.
Cheers
Les
#40643
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Mon Jun 07, 2010 3:15 am Post subject: Re: Comm Antenna |
With the antenna mounted that far aft you might want to verify that the tail hits the ground before the antenna.
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
