dlm34077
Posted: Sat Jun 05, 2010 12:14 pm Post subject: survey |
What rpm is being used for the magneto check and what limits are considered acceptable? magneto drop? and drop difference?
rene(at)felker.com Guest
Posted: Sat Jun 05, 2010 12:46 pm Post subject: survey |
1700 RPM
175 Max drop and 50 different
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM
Sent: Saturday, June 05, 2010 2:13 PM
Subject: survey
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
AV8ORJWC
Posted: Sat Jun 05, 2010 1:26 pm Post subject: survey |
Lycoming, the manufacturer of the powerplant most builders select is the best source of said numbers to establish a baseline. The advantage is to determine if timing, wiring, spark or other issues are standing in the way of making adequate horsepower output which could jeopardize safe flight and certainly take-off. Each Builder of the RV-10 establishers their own numbers based on their extensive research before acquiring the coveted DAR or FAA Inspection Signoff. Choice of spark ignition systems, compression, internal components, fuel used and other issues can skew the use of one other builders choice.
Personally, I would run the question passed Rhonda on what the Dyno tells her dad with the quality units that they provide. They are solid reference sources for magneto driven powerplants.
Choice wisely.
John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene
Sent: Saturday, June 05, 2010 2:19 PM
Subject: RE: survey
1700 RPM
Rene'
801-721-6080
Subject: survey
[quote] http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution - The RV10-List Email Forum -[/b][/b][/b][/b][/b] --> http://www.matronics.com/Navigator?RV10-List[b] - MATRONICS WEB FORUMS -[/b][/b] --> http://forums.matronics.com[b] - List Contribution Web Site -[/b] Thank you for your generous support![/b] -Matt Dralle, List Admin.[/b] --> http://www.matronics.com/contribution[/b] [b]
davidw(at)dddirectories.c Guest
Posted: Mon Jun 07, 2010 5:41 am Post subject: survey |
1800 rpm…..1620-1640, 20 drop difference
Sent: Saturday, June 05, 2010 3:13 PM
Subject: survey
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Deems Davis
Posted: Mon Jun 07, 2010 5:58 am Post subject: survey |
I was getting similar drops as David indicated when doing Mag checks (at) 1800. I now do them (at) 2000 RPM and see a drop of only 100 RPM.
Deems Davis
N519PJ
www.deemsrv10.com
On 6/7/2010 6:36 AM, David Watterson wrote: [quote] <![endif]--> <![endif]-->
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of DLM
Subject: survey
0 1 2 3 4 5 6 7 8 9
0 [b]
