		rayfitton(at)virginmedia. Guest
				 Posted: Fri Jun 11, 2010 10:38 am    Post subject: Poham Europa flyin |
				Is anybody attending this event this weekend
 Ray
 On 11 Jun 2010, at 16:20, Frans Veldman <frans(at)privatepilots.nl> wrote:
  On 06/11/2010 04:39 PM, Raimo Toivio wrote:
 > My solution: I have no oil radiator at all!
 > In the tunnel there is only the water rad !
  That should also be better than the tandem radiator setup. How does it
  behave in warm weather? Can you fly normally in temperatures of 35
  degrees?
 > The cooling system includes also a water thermostat.
 > I think it is "The Must" at least when flying during Finnish winter
 > time.
  Well, you could achieve the same with a cowl flap I think.
 > (OK - I know - some of you are tempted to think a thermostat is a
 > risk.
 > Well - please do not install thermostats in that case - just fly!)
  The reason I don't like thermostats is that you will still have the
  cooling drag, due to dragging air through the radiator, while you
  actually don't want to cool anything.
  With a cowl flap that closes off the air flow through the radiator,
  you
  can also prevent overcooling, but at the same time you reduce drag.
  Frans
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rick(at)amimotormanagemen Guest
				 Posted: Fri Jun 11, 2010 10:51 am    Post subject: Poham Europa flyin |
				Certainly am.
 Rick
 G-RIKS
 Sent using BlackBerry® from Orange
