My 2 Cents on the Landing Gear
flysrv10(at)gmail.com
PostPosted: Wed Apr 26, 2006 6:31 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
I used the same reamer as you have purchased. I found it easier to
insert the reamer from the button, chuck it and pull it through the
hole. If you decide to do this, you may need to grind the blade
shoulders at the reamer stem side to be able to pull up through.
On 4/26/06, Conti, Rick <rick.conti(at)boeing.com> wrote:
Whenever I start a new "kit", I review the instructions several times,
once to ensure I have the necessary tools and parts. The .311" drill
bit appeared to be a problem. I called Van's and received an
interesting answer: I was told a 5/16 bit would be okay. I haven't
installed the gear yet and after reading about loose landing gear I had
second thoughts. I received my .311" reamer from McMaster-Carr (thanks
for the info) yesterday. But is has occurred to me, that 5/16" would be
fine provided the bolt matched. Drilling with a 5/16" bit though the
leg and support would not cause a problem. The problem would be from an
undersized bolt. Would everyone agree 5/16" would be okay with a proper
(precise fit) bolt?
Thank You
Rick Conti
Senior Engineering Manager
The Boeing Company
office: 703 - 414 - 6141
blackberry: 571 - 215 - 6134
PostPosted: Wed Apr 26, 2006 6:46 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Thanks for the advice.
DO NOT ARCHIVE
Thank You
Rick Conti
The Boeing Company
johnwcox(at)pacificnw.com
PostPosted: Thu Apr 27, 2006 6:00 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
No. When the manufacturer calls out a 7.9mm ream then the objective may
just be a tolerance (tight) fit. Fretting and Galling will ensue over a
short period of time. The issue (question) should always be, if this
doesn't work what is the serviceability issue the second time I do it.
Don't try to sand the cadmium coating off either.
Both the mount, the bolt and the gear leg would need replacement.
Calculate the hard dollar cost, then add the effort to retrofit
correctly reamed replacement parts. That includes R & R. In the effort
to cut a corner or two, or save a few dollars, the experimental builder
can give legions of stories of shooting themselves in the proverbial
foot just a few months or years down the road.
That said, I have a source of liquid nitrogen at work which makes such a
clearance the non-issue. Study the concept and calculate the
serviceability cost. It is a corner that I would say NO to. Too much
is riding on it. Take a moment and ask your buddies at work about
altering written aeronautical plans. Talk to your DAR and Tech
Inspector.
Van also says alter the design at your own risk. Until they put 5/16"
in writing, accept no employees dialog on such an issue (unless
admissible in Oregon court).
John Cox - $00.02
Do not Archive
LarryRosen
PostPosted: Thu Apr 27, 2006 6:26 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Not all of us would have access to liquid nitrogen, but dry ice may do
the trick.
Larry
Inspector.
John Cox - $00.02
Do not Archive
Larry Rosen
#40356
N205EN (reserved)
<http>
dlm46007(at)cox.net
PostPosted: Thu Apr 27, 2006 7:32 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Do you really want to shrink the bolt to get a tight fit? How will you ever
remove gear leg in the event of accidental damage that requires it?
owl40188(at)yahoo.com
PostPosted: Thu Apr 27, 2006 7:40 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
I totally agree on this.  The 7.9 mm drill is inexpensive compared to the hardware its being used on, and its easy to locate one.  Its worth several minutes of fuel flying the RV10.
Niko
deutscht(at)rhwhotels.com
PostPosted: Thu Apr 27, 2006 8:22 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
How long should the bit or reamer be?  Is a bit or reamer more preferable?
Tom Deutsch
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nikolaos Napoli
Sent: Thursday, April 27, 2006 10:40 AM
Subject: Re: My 2 Cents on the Landing Gear
Niko
PostPosted: Thu Apr 27, 2006 11:42 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Bob,
I'm not sure I understand. I've never used a reamer and just realized I
shouldn't use an air drill with a reamer. Maybe the hand wrench from my
tap & die set.
What under size hole did you drill before using the .311" reamer?
Please explain the grinding of the shoulders at the reamer stem side to
be able to pull up and through.
Does any of this make sense without using a close tolerance bolt?
Bill suggested using a .3125 reamer with a 5/16" close tolerance bolt.
All of which sounds good.
Thank You
Rick Conti
The Boeing Company
PostPosted: Fri Apr 28, 2006 3:38 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
You can use a rechargable drill with the reamer. Oil the bit well. I
did not have to drill before the reamer. In fact, I found it hard to
have space to drill anything from the top side.
The reamers blades have a step to transition to the shank. Since I
used the reamer backward, I had to grind a slope to be able to pull
the reamer from the bottom of the hole through the top.
Find this reamer and if you want, call me and I will walk you through.
do not archive.
772-460-3907
Rob Kermanj
On 4/27/06, Conti, Rick <rick.conti(at)boeing.com> wrote:
Bob,
tap & die set.
Thank You
Rick Conti
The Boeing Company
JSMcGrew(at)aol.com
PostPosted: Fri Apr 28, 2006 6:00 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
For those of you that haven't gotten to drilling the landing gear mount yet, I just wanted to put in my 2 cents as well. Please, don't take this the wrong way, it's just another way to solve the same problem: I followed Van's instructions exactly and used a .311 / 7.9 mm drill to mount the landing gear. It was easy, I didn't have any problems, and the bolts fit great. I bought the drill from McMaster-Carr for $8.63 including shipping.
Jim
40134
In a message dated 4/28/2006 5:39:04 A.M. Mountain Daylight Time, flysrv10(at)gmail.com writes:
[quote]--> RV10-List message posted by: "Rob Kermanj" <flysrv10(at)gmail.com>
do not archive.
772-460-3907
Rob Kermanj
[quote] --> RV10-List message posted by: "Conti, Rick" <rick.conti(at)boeing.com>
Bob,
tap & die set.
Thank You
Rick Conti
The Boeing Company
Tim(at)MyRV10.com
PostPosted: Fri Apr 28, 2006 6:22 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Ouch, I hope we haven't reached the point where we have to say
"please don't take this the wrong way" to tell people
how you drilled something. Jim, you're doing just great by
taking the time to find the right bit. Thanks for completing
it by posting a source and price too! Keep up the good posting,
and everyone.....always feel free to share your opinions. Sure,
sometimes they'll vary, but yours is just as valuable as
anyone else's. Even if someone's opinion was way backwards,
at least it can bring out the multitude of opposite responses
that can cause people to think. I've had people ask me why
I did something....then say "I never thought about that" when
I gave the explanation. That's the whole point of the list...
getting people to ask a question, and then find all the creative
ways to solve it...and pick the one that either has the proven
track record, or sometimes the innovative idea....your choice.
If it weren't for all of YOUR brains, I'd have wracked mine
even worse and probably never ended up with an airplane that
I like so much.
JSMcGrew(at)aol.com wrote:
[quote] For those of you that haven't gotten to drilling the landing gear mount
including shipping.
Jim
40134
do not archive.
772-460-3907
Rob Kermanj
> Bob,
realized I
from my
> tap & die set.
side to
bolt.
> Thank You
> Rick Conti
> The Boeing Company
PostPosted: Fri Apr 28, 2006 6:39 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Well said. I agree.
DO NOT ARCHIVE
Thank You
Rick Conti
The Boeing Company
jjessen
PostPosted: Fri Apr 28, 2006 6:56 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Tim, nice post, BUT....
Speaking of flying RV-10's and all us poor souls still deburring away, how
about you guys giving us some encouragement by writing about your beautiful
flying machines! Where did you go on your very first trip after you were
let out of the box? What does it handle like in different flying
conditions? What's the view like? Where have you found sight line
difficulties? How does it handle crosswind landings? How is your panel
working out (Tim does not need to answer this; he already has) and what
would you do differently? The list of topics is almost endless! Common!
Give us a breadcrumb or two..., please. I'm not going to be able to get to
OSH, so can't depend on the fireside chats.
John Jessen
~328 (and pictures, too, send pictures)
gommone7(at)bellsouth.net
PostPosted: Fri Apr 28, 2006 7:02 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Hi,can you post the par number for mc Master regarding the .311 drill bit.
Hugo
Date: 2006/04/28 Fri AM 09:59:31 EDT
Jim
40134
do not archive.
772-460-3907
Rob Kermanj
> Bob,
> tap & die set.
> Thank You
> Rick Conti
> The Boeing Company
Tim(at)MyRV10.com
PostPosted: Fri Apr 28, 2006 8:55 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Ok John, it's Friday and so I'm not too interested in continuing
to work the remaining parts of my posterior off anymore, so
I'll take time to type. Wink
Oh, and you really ought to get to OSH.
For my first x/c trip, being Sun-N-Fun, you all know how that
went as I posted already. This past weekend I took another
shorter trip across the state to see Abby from Flightline so
she could see the results of her hard work, and so I could take
them for a ride. I tried to fly at 9500' for some of the trip,
which was planned for 1:15. I had to change between the 5500'
and 9500' level though, as I was flying into worse weather
from better, and had a cloud deck in that range that
went from broken to solid to broken, and I didn't want to
get trapped on top - unplanned.
Climbing to altitude is nice and quick in the -10, and one thing
I keep forgetting is to lead *during* the climb after 5,000'.
I noticed my EGT's dropping way off as I climbed. Once in cruise,
I was amazed at how far I could lean it out. On the trip to
Sun-N-Fun, I just leaned it a bit, not really using precision.
This time I leaned it to peak or very close, and then richened
it up. I found I can get better fuel flows than before.
I have numbers written down but not with me.
I did a round trip with 3 legs, and on the return leg I tried
flying at both 4500' and 8500', trying to find a smooth ride.
I found it smoother, of course, at 8500'. What I noticed
though in setting up my leaning, was I could keep the same
TAS at 8500', but on less fuel, so even with a couple kts
of headwind extra, it's a smoother ride on less fuel.
Last night I read a very cool little rant, and there's a
cool application available. I'd HIGHLY suggest reading
this page: http://www.x-plane.com/cruisealt.html
One thing I'm still squeamish on though is turbulence in
the -10. Va is about 125 kts. You're cruising so far
above that, that I get really "puckered" when I hit some
bumps. The small bumps don't bother me, but it's the
memory of my big bump during transition training (Yes
John, I'm scarred for life. Wink ) that gets me all uptight.
I feel like if I hit a couple bumps at high speed, that
perhaps the big one is just ahead. So I search for
smooth air as much as possible.
There are no...and I mean NO, line of sight or visibility
issues in the -10. Period. The view is great in most
directions other than backwards.
Randy called me a couple nights ago and we agreed on one thing
for sure... Crosswinds in the -10 are a very easy. The -10
has so much rudder, and it just handles crosswinds great.
I have much less aversion to 20-25Kt winds than I had before,
even if they're not straight on. Landing the -10 hasn't
changed for me since the first flight...it's really easy.
I did drop one in at one point, but that was an oddity. Most
landings are ones that other people don't just find
acceptable, but actually impressive, and that's not all me...
a lot of it's the plane.
As for handling, people wanting a -6/-7 handling will be
sorely disappointed, but people who want a solid plane
that's good for IFR flight will love it. Oh, when
I say disappointed, that's not to say that it isn't light
and great feeling. It just doesn't have the roll and
ultra-light feel that those planes would. The -10 controls
get VERY heavy at higher airspeeds. I don't think you'd
have a very easy time rolling the -10 at 140+ Kts. Your
stick takes a LOT of force in roll at those speeds. Pitch
is still very light. Below 120Kts, the -10 is much more
roll-maneuverable. Keeping in mind the wish for a stable
IFR platform, this fits my needs perfectly. The Sundowner
though was a plane that, due to it's slower speeds,
was a solid but more roll-maneuverable feeling plane.
The -10 should be very close, but only at it's lower
speed range.
I've mentioned before the need for slower trim speeds in
cruise. This is *kind of* hard for me to stand solidly
behind. I have been able to get trimmed up pretty nicely
with the thing running at full trim speed. But, just due
to the extreme quickness that you could get into a very
hard climb or descent at cruise, I still think an automatic
speed switch would be a good idea above 120 Kts or so.
It is necessary...no, not at all. But, the one time you
have something go wrong at high speeds, like bumping
the button, you hopefully will make it though it with
no problems...it could be scary. If nothing were to ever
go wrong though, I'd see no reason to take the time to
wire in a speed reduction. For me, it's cheap enough so
I'll probably do it, but it's on the back burner and will
likely happen in the off season.
Back to the old Yaw damper discussions... I tried hard in the
bumps on this last trip to see if I really thought it needed
it. I guess I'm stuck about where I am on the trim. I
personally don't know that I'll ever add a yaw damper.
And I wouldn't maybe recommend spending the money on the servo
until you're flying already and can see for yourself. If
you want rock solid "no-wiggles" in your tail though, it's
something I guess to consider. I've never flown with one,
so I don't know how effective they are. What I can say
though is that there, in turbulence, a slight tail wiggle
in the -10. It hasn't bothered my kids so far, and at
present I don't intend to add a yaw damper myself. It's
not at all what I'd consider too awful.
Oh, and they're about 20 times more fun to fly than they
are to build, so that should give you some motivation
to finish. Wink
John Jessen
JSMcGrew(at)aol.com
PostPosted: Fri Apr 28, 2006 8:58 pm    Post subject: My 2 Cents on the Landing Gear Reply with quote
Part number / description below from www.mcmaster.com:
Line Quantity Part Number Description Unit Price Total Price   Ships 1 1
Each 30565A304 Hvy Duty Metric Hss Jobbers' Twist Drill Bit 7.9 mm Size, 114mm O'all Length, 81mm Flute Length
$4.13 $4.13
In a message dated 4/28/2006 9:08:23 A.M. Mountain Daylight Time, gommone7(at)bellsouth.net writes:
[quote]--> RV10-List message posted by: <gommone7(at)bellsouth.net>
Hugo
Jim
40134
do not archive.
772-460-3907
Rob Kermanj
> Bob,
> tap & die set.
>  Thank You
> Rick Conti
> The  Boeing Company
Bill Schlatterer
PostPosted: Sat Apr 29, 2006 7:03 am    Post subject: My 2 Cents on the Landing Gear Reply with quote
Rick, just a follow up. The only mission here is to get a uniform hole with
no play or as little play as possible. A 5/16 bolt is .3125 so a .3111
reamer will make any 5/16 bolt a snug fit. ( 3125-3111 = .0014) A 3125
reamer with a close tolerance bolt should also be fine. I used the straight
fluted reamer in an electric hand drill turning fairly slowly with some
Bolube for lubricant and it was way less trouble than I ever imagined. I
spent way more time agonizing than doing. It went like butter.
Many folks recommend putting the "shank" of the reamer through the hole fist
and then attaching the drill and pulling the reamer back through. That's
because the shoulder on the back of the reamer has a little slope to it and
the front does not. I did not find it to be a problem just using it like a
drill. Going directly to a 3125 did not require "pre-drilling" so I would
think starting with a 3111 would not either.
The only reason to use a reamer instead of a drill is that drills leave a
somewhat triangular hole instead of a truly round hole. The round hole with
a close tolerance bolt or slightly oversize will obviously have more bearing
surface in the reamed hole than in the drilled hole.
Many folks have just drilled them and it seems to work fine so I would think
that any combination of the reamer options would be fine. First best option
is the 3111 and then 5/16 reamer 3125 and a CT bolt.
My .02
Bill S
7a
PostPosted: Sun Apr 30, 2006 2:07 pm    Post subject: My 2 Cents on the Landing Gear Reply with quote
All of this sounds good to me. Thanks!!
DO NOT ARCHIVE
Thank You
Rick Conti
The Boeing Company
