bakerocb
Posted: Sun Jun 13, 2010 5:13 am Post subject: Seeing Matronics List Attachments |
bakerocb
Posted: Mon Jun 21, 2010 3:54 am Post subject: Seeing Matronics List Attachments |
6/21/2010
Hello Fellow KIS Listers, I wrote: " PS: There is sort of a gotcha. I posted
a jpg picture on the KIS list (see here I hope):
I have modified (shrunk) the original posted vortex generator picture
significantly. Please see if this attached view is better for you.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
189.87 KB |
5608 Time(s) |
ftyoder(at)yoderbuilt.com Guest
Posted: Mon Jun 21, 2010 6:04 am Post subject: Seeing Matronics List Attachments |
'OC',
What are your test results? ( On the vortex generator. )
lgdavid(at)roadrunner.com Guest
Posted: Mon Jun 21, 2010 2:09 pm Post subject: Seeing Matronics List Attachments |
OC, you can shrink the display of the picture by holding the control key down and pressing the minus key a couple of times. (This works in Firefox and I assume other browsers.) Of course the accompanying text will shrink also. It looks like the device is about 6-8 inches in front of the leading edge of the tail and the device itself is about 6-8 inches long. Am I guessing right on the sizing? Larry
On 6/21/2010 4:53:24 AM, bakerocb(at)cox.net (bakerocb(at)cox.net) wrote:
[quote] 6/21/2010
> http://forums.matronics.com/viewtopic.php?t=71560
> and the picture posted just fine except that its layout on the forum was
> so huge such that one had to scroll all over the place to find the area of
bakerocb
Posted: Mon Jun 21, 2010 7:24 pm Post subject: Seeing Matronics List Attachments |
6/21/2010
Hello Larry, Thanks for the picture tip.
These vortex generators go on each side of the fuselage in front of the
wing. Their purpose is to generate higher energy air in the area of the wing
to fuselage juncture.
They are more on the order of 4 inches long -- that is all the aluminum
angle that I had available.
Take a look at the ones on the Cirrus airplanes to see what I am trying to
replicate.
