Ko lb-List: New guy with repair questions
Goto page 1, 2  Next
frank.goodnight(at)att.ne
PostPosted: Tue Jun 22, 2010 5:51 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Hi John and all,
Just idle thoughts , could someone tell me why it would not be ok to sleeve the broken area with an inside
and a outside sleeve , say 18to 24 in long, T4 or T6 , plenty of rivits and whatever thickness you are comfy with.
Frank Goodnight
Firestar 2
Brownsville, TX
Sent: Tue, June 22, 2010 6:59:28 PM
Subject: Re: New guy with repair questions
PostPosted: Tue Jun 22, 2010 6:02 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
No way I would ever be comfortable with a spliced tailboom.
May be an acceptable method of repair, but I would not go that route. Too much riding on it for me.
Where I play is very unforgiving for dumb mistakes.
slyck(at)frontiernet.net
-or just chop it at the break and use a short tail Smile
Seriously, if you could find tubing that telescoped internally in a perfect fit, stuck in about a foot, it would be
strong enough. You might run into a little problem with the legal angle even though it is experimental.
BB
On 22, Jun 2010, at 9:50 PM, frank goodnight wrote:
Hi John and all,
Frank Goodnight
Firestar 2
Brownsville, TX
From: John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
flykolb(at)pa.net
PostPosted: Tue Jun 22, 2010 6:34 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Frank and all,
A properly designed spice could provide 100% of the tube strength.  The Laser had a spliced wing spar.  The root spar was 5” x ¼” wall. The middle spar was 5” x 1/8” wall and the outer spar was 5” x .049” wall.  The 5” x 1/8” wall spar was turned down at the end so the 5” x .049 was a nice slip fit.  A splice could be made in a similar way.  A short section, say 12” would be turned down on both ends leaving a short ridge in the center to butt the fuselage tube against – this would ensure the splice was centered.  Stresses at the tail are much less than further forward – except for improper trailering!  The very end of the turned down section would need to be rounded so as to not stress the fuselage tube – that is how we did the Laser.   The rivets would transmit the torsional loads and the splice tube itself would take up most of the bending strength even without rivets.  The length of the splice would need to be determined, 1 ft might not be enough, but 2 ft would be too much … so somewhere in between.  This is an easy problem to solve using Cosmos FEA and Solidworks.
The splice would be made of 6061-T6 and the turned down section would be stronger than the 6063 alum the fuselage is made from.
The rivet pattern would need to be engineered properly, another task for Cosmos.
Dennis
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of frank goodnight
Sent: Tuesday, June 22, 2010 9:50 PM
Subject: Re: Ko lb-List: New guy with repair questions
Hi John and all,
Frank Goodnight
Firestar 2
Brownsville, TX
rickofudall
PostPosted: Tue Jun 22, 2010 6:37 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
The biggest problem would be finding telescoping sizes of tubing. For an internal splice you'd need 4 7/8" .058 or .065 wall. Not exactly a common size. Same for an external sleeve, 5 1/8" .058 wall isn't listed anywhere I can find either. Better to just go the route you've started down and replace the tube. Since you've already been in touch with Travis, have him send you a new "H" frame. You'll play hell trying to match up the rivet holes in the old one and leaving them unfilled and drilling new ones is just asking for a place for cracks to start.
Rick Girard
On Tue, Jun 22, 2010 at 9:02 PM, robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote:
[quote] -or just chop it at the break and use a short tail Smile
BB
Hi John and all,
Frank Goodnight
Firestar 2
Brownsville, TX
To: kolb-list(at)matronics.com (kolb-list(at)matronics.com)
tp://forums.matronics.com
PostPosted: Tue Jun 22, 2010 6:45 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Rick:
The biggest problem would be to find 5" tubes that were precisely sized.
These tubes are manufactured primarily for irrigation pipe. Circumference of a 6" tube can change a lot from one end to the next. Getting a tube to fit a ring can be a pain in the butt, when factoring in the ring can also be a tad too small
Rick Girard
PostPosted: Tue Jun 22, 2010 6:48 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Hit the wrong darn button before I finished writing my response.
What I was trying to say was no two tubes, 5" and 6", are created equal. No two ends of one of those tubes will be the same size.
Arksey(at)aol.com
PostPosted: Tue Jun 22, 2010 7:00 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Hi Frank,
I saw a Drifter that had the boom tube spliced...looked good...was done by a experenced repair man....but it was a neat square cut on the boom tube with a sleeve inside that was quite long.....looked to me like it would be ok....but in Chris's case the boom tube looks to bad to be spliced....I agree with John H. best to replace the whole boom tube....will be interesting to find out how this happened.....bad deal....Jim Swan
FIRESTAR ll 503 Michigan jswan
GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825
Arksey(at)aol.com
Hi John and all,
Frank Goodnight
Firestar 2
Brownsville, TX
Hi Frank,
Dana
PostPosted: Tue Jun 22, 2010 7:23 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
When splicing a tube like that, a common method is to use a piece of the original tube, split lengthwise just enough so it will squeeze down into the original tube. Not as strong as the original in torsion, but a similar outside sleeve 180° apart would handle that and then some... though close to the tail where this damage should normally be much lower stressed than farther forward.
Based on the pictures, it appears that it's cracked around the bottom.... correct? In this case it looks as though the tailboom was forced upwards aft of this. Where was the support relative to the brek?
Rick, I feel stupid. I've wondered how one would replace a tailboom and match the rivet holes. I never thought of the obvious, replace the H-section with a new undrilled one along with the tailboom.
-Dana
Why did the chicken cross the Mobius strip? To get to the other, er, um.... [quote][b]
Chris_A
PostPosted: Tue Jun 22, 2010 8:49 pm    Post subject: Re: Ko lb-List: New guy with repair questions Reply with quote
I did toy with the idea of repairing it and my thought was to take a piece of 5" O.D. .125 wall 6061 T6, and make a "coupler" out of it by turning the walls down .052 at both ends so they would slide into either end of the cut tube and leave the center of the coupler untouched so that when everything was slid together the O.D. would be flush. Then rivet the ends. But I've already got the new one paid for.
racerjerry
PostPosted: Wed Jun 23, 2010 7:13 am    Post subject: Re: Ko lb-List: New guy with repair questions Reply with quote
As Dana said, “When splicing a tube like that, a common method is to use a piece of the original tube, split lengthwise just enough so it will squeeze down [tightly] into the original tube.� But STRESS CONCENTRATION problems have been overlooked, which would be of critical importance when splicing a fuselage boom tube. Chapter 4 of AC 43.13-1B is useful as a guide. A split sleeve could be used if the ends were cut off at a large angle (about 30 degrees from lengthwise axis) in order to spread the load along the tubing and prevent stress concentration in one spot. Such a repair should work fine at the tail end, but is just too scary near the highly loaded fuselage pod end of the tube. Also, since it would be impossible to buck solid aircraft rivets, self plugging Cherry aerospace rivets (CR9163 – available through Aircraft Spruce) should be used for the repair. A repair using pop rivets would not be nearly as strong and the pop rivets would be subject to loosening after repeated load cycles.
I am very glad to hear that you ordered a new tube.
Jerry King
Eugene Zimmerman
PostPosted: Wed Jun 23, 2010 9:10 am    Post subject: Ko lb-List: New guy with repair questions Reply with quote
-Dana
Kolb Rebuilders,
The best way to exactly match rivet holes and reuse the H-section is
to make a paper tube template. After removing all the rivets and the
H-section, wrap the tube tightly with a large piece of paper and tape
the paper together so that will remain together in the shape of a
paper tube after it is slid off the undamaged end of the boom tube. To
secure the paper to the boom, temporarily tape this paper tube to the
boom over the rivet holes and the bolt hole and then drill all the
holes in the paper. Now you have made an exact template. Carefully
slide the paper sleeve from the old boom and slide it in place over
the new tube and tape it securely. Carefully center punch and drill
the holes in the paper for the main bolt first, and then do the four
rivets at the ends of each leg of the H-section. Now carefully
reinsert the H-section in place and insert the main bolt. Then rivet
the ends of the H-section legs in place, MAKING SURE the H-section
legs are WEDGED TIGHT against the inside of the boom tube before
riveting. Then center punch, drill, and rivet the remaining holes.
p.s.
Make sure all burrs are removed from the rivet holes in the H-section
before sliding in place. A 2x4 on either side of the boom with a C
clamp to squeeze the tube a slight bit will make a tight fitting H-
section much easier to install.
Gene
PostPosted: Wed Jun 23, 2010 11:38 am    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Thanks Eugene,
After spending at least 50 years as a mechanic it never fails to amaze me how little I know . One reason I love the list
is that I learn so much from it . I'll remember that little gem you gave us , hope I never have to use it but it sure will be handy
if I do.
Frank Goodnight
Sent: Wed, June 23, 2010 12:10:14 PM
Subject: Re: Re: Ko lb-List: New guy with repair questions
--> Kolb-List message posted by: Eugene Zimmerman <etzimm(at)gmail.com (etzimm(at)gmail.com)>
-Dana
Kolb Rebuilders,
The best way to exactly match rivet holes and reuse the H-section is to make a paper tube template. After removing all the rivets and the H-section, wrap the tube tightly with a large piece of paper and tape the paper together so that will remain together in the shape of a paper tube after it is slid off the undamaged end of the boom tube. To secure the paper to the boom, temporarily tape this paper tube to the boom over the rivet holes and the bolt hole and then drill all the holes in the paper. Now you have made an exact template. Carefully slide the paper sleeve from the old boom and slide it in place over the new tube and tape it securely. Carefully center punch and drill the holes in the paper for the main bolt first, and then do the four rivets at the ends of each leg of the H-section. Now carefully reinsert the H-section in place and insert the main bolt. Then rivet the ends of the H-section legs in place, MAKING SURE the H-section legs are WEDGED TIGHT against the inside of the boom tube before riveting. Then center punch, drill, and rivet the remaining holes.
p.s.
Make sure all burrs are removed from the rivet holes in the H-section before sliding in place. A 2x4 on either side of the boom with a C clamp to squeeze the tube a slight bit will make a tight fitting H-section much easier to
Chris_A
PostPosted: Wed Jun 23, 2010 3:49 pm    Post subject: Re: Ko lb-List: New guy with repair questions Reply with quote
-Dana
Kolb Rebuilders,
p.s.
Gene
Gene,
Thank you for posting this. This is exactly what I came up with after racking my brain last night. My plan was to do this for both ends of the tube and verify with the plans. Is that an unrealistic expectation?
Thank you guys for all the advice, none of it has fallen on deaf ears.
Chris
elleryweld(at)aol.com
PostPosted: Wed Jun 23, 2010 4:40 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
I am not trying to make anyone mad but have you ever tried to use Paper for a template working with Metal I have been a Welder Fabricator most of my life and Paper does not work very well other than to make drawings on
Ellery Batchelder Jr.
Eugene Zimmerman
PostPosted: Wed Jun 23, 2010 6:02 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Yup,
Worked perfect for me on the boom tubes and the wing spars on the three major rebuilds that I have done.
Nothing wrong with your way though if you don't mind the extra work of cutting apart the old tubes.
Gene
mdnanwelch7(at)hotmail.co
PostPosted: Wed Jun 23, 2010 6:26 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Ellery,
  Maybe Gene used stiff paper, I don't know.  His method seems to work well for him.
  I recall needing to match rivet holes on something once, I can't remember exactly what it was.
  If I needed to match all the rivets holes along a line (like a boom tube), I would do this method again;
1)  First, drill out each end rivet completely (just the end rivet!).
2) Then cut a piece of Lexan big enough to cover every rivet hole in the line sufficiently (say, 2" x 16").
3)  Drill a hole near one end of the Lexan, and secure it in place with a cleco, to that one drilled hole.
4)  Now, with the Lexan taped firmly, visually line up and drill through the other end rivet hole, and insert your second cleco.
5)  Now, you've got a rectangular piece of Lexan stuck in place with a cleco at each end of the line of rivets.
6)  Since it is transparent, you can now drill a 1/16" hole perfectly centered on each rivet.  You do NOT want to drill out the rivet.....it's only a locating hole for every remaining rivet.
7)  Next, after you've drilled a tiny hole centered on every remaining rivet, remove the Lexan.  You can now drill out all the rivets, and remove the "H" brace.
Cool  When reinstalling the H brace, all you need is to do is locate the end rivet holes, and hold the H brace in place with clecos, but you'll want to make sure you include your Lexan when you put your clecos in.
9)  All that's left is to drill each locating hole deep enough into your boom tube with that 1/16" drillbit to where when you drill the holes bigger the 1/8" drillbit doesn't wander.  If you've got a good, sharp 1/16" drillbit, you could probably go ahead and drill each hole all the way through.
  Lexan may be an alternate for some cases where paper might not work.
  Just an idea I did once........
Mike Welch
MkIII
Date: Wed, 23 Jun 2010 20:34:14 -0400
by0ung(at)brigham.net
PostPosted: Wed Jun 23, 2010 8:53 pm    Post subject: Ko lb-List: New guy with repair questions Reply with quote
Mike Welch
MkIII
i used something similar..... before building the first time i asked a friend with a mil to help by building me a jig, (any machine shop should be able to help build the jig) i had him drill a line of holes 1/2 inch apart in a perfect line in a piece of 1/4 inch thick alum. i would drill one hole then position my drill guide over the piece with a cleco. then using the guide would drill the other end and fasten with a cleco. then i would have a guide to drill the rest of the holes ... all perfectly in line..... all perfectly spaced... and using the guide eliminated the need for center punching migrating drills etc. when re building a part.... just locate the first hole and use the jig.
boyd young
mkiii
Carl Tosh
PostPosted: Thu Jun 24, 2010 10:57 am    Post subject: Ko lb-List: New guy with repair questions Reply with quote
I agree with Ellery on the paper. I cut the old tube and sectioned it for the rivet location. Drilled the two end holes, clecoed it used the section as a template for the rest of the holes. I had to warp my new H section slightly to be able to use the old boom tube. Just opposite of what has been discussed, and cussed. My H section was very poorly fabricated by original builder.
Carl Tosh Ultrastar Rebuilder, Micro Mong Builder Machinist, Welder, Millwright
Date: Thursday, June 24, 2010, 12:34 AM
mongsterone
Goto page 1, 2  Next
Page 1 of 2
