		bgreen(at)bimi.org Guest
				 Posted: Fri Jun 25, 2010 6:02 am    Post subject: Kolb-List Digest: 5 Msgs - 06/24/10 |
				Concerning the installation of the "H" bracket in the boom tube:  I preferred not to clamp or put bending pressure on the outside of boom tube...   What I did was put the "H" bracket in place and using either 1" or 2" think boards I placed one on the top leg of the "H" bracket and the other on the opposite leg.  I then pushed a wedge shaped 2x4 between the two flat boards causing the two bracket legs to flex to a tight fit against the inner walls of the tube.   Not much pressure was required and this insured a snug fit between the two ("H" bracket and boom tube) for riveting purposes.
 As Richard Pike says... "For what it is worth"...
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Fri Jun 25, 2010 6:35 am    Post subject: Kolb-List Digest: 5 Msgs - 06/24/10 |
				 	  | Quote: | 	 		   Concerning the installation of the "H" bracket in the boom tube:  I
  tube...    > Bob
 Cabinet maker's/carpenter's wooden clamps work well.  Only slight pressure
 is required to get the job done.
  _________________ John Hauck
Titus, Alabama |
		GeoB
				 Posted: Fri Jun 25, 2010 8:01 am    Post subject: Kolb-List Digest: 5 Msgs - 06/24/10 |
				 	  | Quote: | 	 		  The best way to exactly match rivet holes and reuse the H-section is to
 make a paper tube template.
 I shouldn't even pipe up as I am not a pilot and don't have a Kolb. However,
 fine points of etiquette have always escaped me so...
 I have JUST retired after a long and glorious career in GIS. Think automated
 mapping, spatial analysis, aerial photos, GPS, HUGE plotters and scanners.
 We quit using paper for critical drawings years ago as it is not
 dimensionally stable. Paper stretches, humidity affects it, John down the
 hall leaves it lying around with coffee stains...
 Maybe use mylar, eh?
 GeoB
  _________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
