Z-31B Ground Power Contactor Diode
jonlaury
PostPosted: Tue Jul 06, 2010 10:39 am    Post subject: Z-31B Ground Power Contactor Diode Reply with quote
In Z-31B, I'm using a continuous duty contactor with one coil post, like the one shown in the diagram and labled"Existing Battery Contactor", for a Grd. Pwr. Contactor.
I'm unsure about where to place and how to orient the diode for a GP jack when using the CD contactor.
Thanks for any help,
J
PostPosted: Tue Jul 06, 2010 1:29 pm    Post subject: Z-31B Ground Power Contactor Diode Reply with quote
The banded end of the diode connects to the
"BAT" terminal of the contactor which in turn
faces incoming power from the ground power
connector.
The other end of the diode goes to the small
coil terminal which is switched to ground
to energize the contactor and bring ground
power onto the bus.
jonlaury
PostPosted: Wed Jul 07, 2010 8:45 am    Post subject: Re: Z-31B Ground Power Contactor Diode Reply with quote
Thank you, sir.
J
