Posted: Wed Jul 07, 2010 6:29 am Post subject: Firefly Slide Show |
Jack- How are you doing with the MZ34 engine? Haven't heard anything for a while.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Posted: Sun Jul 11, 2010 3:31 pm Post subject: Firefly Slide Show |
Date: Wed, 7 Jul 2010 07:29:18 -0700 (PDT)
From: william sullivan <williamtsullivan(at)att.net>
while.
Bill,
Finally, I believe, I have the Tillotson carburetor problem resolved. The
last time I disassembled it, I blew out all the galleys with compressed air.
Some white stuff blew out, but I could not find it afterwards to see what
it was. They use a Eastman product to help seal the press in plugs. I
have found some of it loose on the control diaphragm side of the plug. This
carburetor was designed before ethanol, and may be the sealer is not
compatible with ethanol. After blowing it out I checked the high speed
check valve action and it was better than what I thought it was on previous
attempts. To make it easier to start carburetor adjustment from scratch, I
brought some adjuster tubes forward and under the wing crossover beam so the
I could adjust the needles with the engine running.
Any way the engine is running, with good and seemingly stable EGT and CHT.
Too early to be sure. Tomorrow I will start unwrapping the Tiny-tach lead
to get a good tach reading. Then I can set the propeller and go fly.
Jack B. Hart FF004
Winchester, IN
DAquaNut(at)aol.com Guest
Posted: Sun Jul 11, 2010 6:42 pm Post subject: Firefly Slide Show |
Jack,
Good to hear a report on the MZ. Are you using a Mister Funnel when you pump fuel. Two different times I have found white stringy stuff in my gas. I dont know if that is related to the alcohol or not. I dont have a clue what it is. Hope things go your way!
Ed Diebel FF( 062)
In a message dated 7/11/2010 6:31:53 P.M. Central Daylight Time, jbhart(at)onlyinternet.net writes:
| Quote: | This
attempts. |
