N811WT flies!
sarg314(at)gmail.com
PostPosted: Sat Jul 17, 2010 11:15 am    Post subject: N811WT flies! Reply with quote
Test pilot Joe Shetterly took N811WT off this morning about 7am and stayed close to Ryan Field for about an hour.  I was expecting the usual cooling problems, but Joe says the cylinder head temps in my Aerosport Power rebuilt IO-360-B2B stayed below 400 F and the oil temp was at 210, and this is in Tucson in the summer time.  Stall clean was 45 knots - right on Van's numbers.  I made a fiberglass cooling plenum for the thing, maybe that has had some benefit.  At this point I really don't know.  It hasn't seemed to cause a problem at least.
Only squawk was that when he throttled back to 1700 rpm after half an hour of high cruise operation, the engine loped for a while.  He described it as the typical fuel injected engine loping. Boost pump made no difference.   After a few minutes it settled down and was running smooth when he was in the pattern.  Perhaps that will settle down as the engine breaks-in? I'll talk to Bart at Aerosport about it.
I haven't flown it yet.  I get my transition training on tuesday and wednesday in an RV-7A at Gillespie Field in San Diego, so I will probably fly next Friday.
I couldn't have done it without The List!
Tom Sargent, RV-6A with air under the tires after a mere 12 years.
Painless
PostPosted: Sat Jul 17, 2010 11:31 am    Post subject: N811WT flies! Reply with quote
Tom:
Like you, I have been on the list for what seems an eternity, and have noted your posts over the years. Just want to wish you congrats after a long build time and wish you the best during phase I testing and beyond.
Well Done!
Best Regards.
Jeff Orear
RV6A N782P
On Jul 17, 2010, at 2:13 PM, thomas sargent wrote:
[quote]Test pilot Joe Shetterly took N811WT off this morning about 7am and stayed close to Ryan Field for about an hour. I was expecting the usual cooling problems, but Joe says the cylinder head temps in my Aerosport Power rebuilt IO-360-B2B stayed below 400 F and the oil temp was at 210, and this is in Tucson in the summer time. Stall clean was 45 knots - right on Van's numbers. I made a fiberglass cooling plenum for the thing, maybe that has had some benefit. At this point I really don't know. It hasn't seemed to cause a problem at least.
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Jeff Orear
RV6A N782P
Peshtigo, WI
recapen(at)earthlink.net
PostPosted: Sat Jul 17, 2010 11:38 am    Post subject: N811WT flies! Reply with quote
Congrats - now the real fun begins.
One of the things I did with my AFP injection system was to reduce the size of the restrictors from .028 to .024 - I then added one land of idle mixture adjustment. Mine's an IO360B1F6 with 9.2:1 pistons so YMMV. You might need a cooling shroud on your fuel pump with fresh air from the cooling plenum - that should help your running temp on the fuel pump. I have since balanced the injectors so the all peak within .1gph - adds to the smoothness.
Break-in and 'regular' oil will drop the temps too.
The list is a treasure trove....
Ralph Capen
RV6A N822AR (at) N06 75hrs
crowbotham(at)hotmail.com
PostPosted: Sun Jul 18, 2010 8:10 am    Post subject: N811WT flies! Reply with quote
Hi Tom,
CONGRATULLATIONS  and WELL DONE !!!!
Chuck & Dave Rowbotham
RV-8A (sold)
RV-9A building
Date: Sat, 17 Jul 2010 12:13:59 -0700
Subject: N811WT flies!
To: rv-list(at)matronics.com
Site Admin
PostPosted: Sun Jul 18, 2010 8:38 am    Post subject: N811WT flies! Reply with quote
Congratulations, Tom!!! Well, done!
Post some pictures of your RV-6A. Instrument panel and in the air too!
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Working on Replacement Wheel Pants & Oil Door
I couldn't have done it without The List!Â
