jdubner(at)yahoo.com Guest
Posted: Thu Apr 27, 2006 8:24 am Post subject: Canopy Latched Sensor |
I'm looking for a better way to implement the canopy unlatched warning
system on a Long-EZ. The standard method is to use a small microswitch
that responds to "canopy latched". (This is not the same as "canopy
closed", which would be easy enough to implement but I want a "latched"
indication.)
Here's an illustration of the standard system:
http://users.lewiston.com/hth/jd/CanopyLockMicroswitch.jpg
When the canopy locking handle is pushed forward (left in the image) far
enough to latch the canopy locking mechanism, the head of the screw on
the handle (at the right in the image) fits in the hole on the latch and
actives the microswitch through its (specially bent) lever.
I'm not happy with the microswitch as it doesn't hold up well under use
and wonder if any Aeroelectric Connection readers can come up with a
better idea. I've searched for optical interrupters but can't find one
with a gap large enough for the head of the relatively large #10 screw.
I'm not familiar with any specific reflective-type optical sensors but
I'm guessing that would be the way to go.
Any ideas?
Joe
Long-EZ 821RP
Lewiston, ID
BigD(at)DaveMorris.com Guest
Posted: Thu Apr 27, 2006 10:28 am Post subject: Canopy Latched Sensor |
Any two pieces of metal touching constitutes a switch. You don't
have to add a microswitch to the contraption to make it work. When
the screw on the handle touches the metal strip, you've got contact.
Dave Morris
indication.)
Any ideas?
Joe
Long-EZ 821RP
Lewiston, ID
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu Apr 27, 2006 2:00 pm Post subject: Canopy Latched Sensor |
On Apr 27, 2006, at 9:21 AM, Joe Dubner wrote:
Quote: |
<jdubner(at)yahoo.com>
What about a small magnet and a magnetic reed switch. You can get
them as window and door sensors from your local burglar alarm
company. They probably have them at Radio Shack too.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
Antoine de Saint-Exupry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Thu Apr 27, 2006 2:22 pm Post subject: Canopy Latched Sensor |
Thanks, Dave but the metal-to-metal contact isn't reliable. The screw
head fits loosely inside the hole in the latch and the screw's grip
doesn't necessarily make solid contact with the edge of the .020" SS
latch. And there's no pressure on the "contacts".
Still looking for an optical solution ...
Joe
Dave Morris
>indication.)
>Any ideas?
>Thanks,
>Joe
>Long-EZ 821RP
>Lewiston, ID
john(at)ballofshame.com Guest
Posted: Thu Apr 27, 2006 6:59 pm Post subject: Canopy Latched Sensor |
An optical solution for this is difficult because the screw head won't
protrude out enough. I could probably rig something up but I don't
think it would be very reliable at all.
A Hall effect sensor might work. You'd have to find a way to get the
magnet into the screw head somehow. There are other ways to do it.
Once again, though, with vibration I don't think this would be very
reliable. It would take some work, anyhow, but this is better than
rigging something up with LED's and photodiodes I think. One thing
that might work is the put the magnet on the lever part and the sensor
near the edge of the latch. Since the whole latch moves up when it
latches (i.e. they're a little closer to each other when the screw's in the
hole than when it's not) you may be able to tune it reliably like this. I
dunno.
Honestly, I would just use a switch. That microswitch setup looks
pretty flaky. Personally I would make a leaf switch out of two thin
pieces of metal seperated by a small plastic washer. They're bent
towards each other slightly. Bolt goes in, leafs touch, and presto.
Simple, light and reliable. In 5 or 10 years when some surface
corrosion (or whatever) makes the switch not work anymore, replace it
with another $ 0.10 worth of metal (or do it every annual if you like).
just my $.02
-John Coloccia
indication.)
Any ideas?
Joe
Long-EZ 821RP
Lewiston, ID
Neal.George(at)maxwell.af Guest
Posted: Fri Apr 28, 2006 4:50 am Post subject: Canopy Latched Sensor |
Joe -
Twist the end of the stainless strap 90-degrees and mount the optical
sensor around the end.
The screw head will push it out of the gate to break the optical path.
Neal
334-953-4137
RV-7 N8ZG wiring Z13-8
Joe
Quote: | >system on a Long-EZ. The standard method is to use a small
>microswitch that responds to "canopy latched". (This is not the same
>as "canopy closed", which would be easy enough to implement but I want
a "latched"
