		daveleikam(at)wi.rr.com Guest
				 Posted: Wed Jul 21, 2010 2:19 pm    Post subject: Lifting the fusalage without wings |
				I know this has been discussed, and I could not  find the thread I was looking for, but what is a good way to lift the airframe  off the gear to install the wheel pants?  Engine and prop are  installed.  Photos?
  Thanks!
  Dave Leikam
 RV-10 N89DA
 Muskego,  WI
		MauleDriver(at)nc.rr.com Guest
				 Posted: Wed Jul 21, 2010 4:15 pm    Post subject: Lifting the fusalage without wings |
				Try looking here:
 http://www.mykitlog.com/users/category.php?user=MauleDriver&project=224&category=5629
 I used the engine hoist along with some oak 1.5"X1" sticks underneath
 the spar stubs.  I used shorter lengths to use on 2 hydraulic jacks to
 get it up then rested the whole thing on the 2 sticks and the engine
 hoist.  You can level the fuse with hoist.
 Later, needing the sticks out of the way for strut work, I used a cut
 down saw horse on top of 4 paint cans to hold the spar center section up
 so I could remove the sticks.  Again, the engine hoist allows you to level.
 The tripod at the tail you may see in the photos was non-functional.
 Hope that helps.
 Bill "sand fill sand fill" Watson
 Dave Leikam wrote:
  	  | Quote: | 	 		   I know this has been discussed, and I could not find the thread I was
  Thanks!
  Dave Leikam
  RV-10 N89DA
  Muskego, WI
		Eric_Kallio
  Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
				 Posted: Wed Jul 21, 2010 4:39 pm    Post subject: Re: Lifting the fusalage without wings |
				Dave, I used a scissor jack under the fork for the nose when needed. To get the mains up I ran a passed very well padded board under the aft baggage bulkhead where the tailcone joins the forward fuse. I put a jack on a stand on one side and the engine hoist on the other and progressively lifted and leveled using a combination of the lifting devices. Never left it up for too long, but it worked great for what I needed to do, and it kept the area around the gear legs clear for working without worrying about hitting my supports.
 Eric
		Strasnuts
  Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
				 Posted: Wed Jul 21, 2010 4:48 pm    Post subject: Lifting the fusalage without wings |
				I made two stainless steel angled stands that bolt into the fuselage spar attach point and have adjustable feet to level for wheel pants installation. Anyone can use them but they are probably expensive to ship.
 On Jul 21, 2010, at 18:39, "Eric_Kallio" <scout019(at)msn.com> wrote:
  Eric
  http://forums.matronics.com/viewtopic.php?p=305860#305860
  _________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
