frank.goodnight(at)att.ne Guest
Posted: Fri Jul 16, 2010 2:20 pm Post subject: MidValleyA/P: Good Gas |
----- Forwarded Message ----
To: MidValleyPOA <mvpoa(at)Cubc.net>
Sent: Fri, July 16, 2010 10:38:10 AM
Subject: MidValleyA/P: Good Gas
Many of you probably know of this site already, but I just ran across it. It lists ethanol free gas stations by state.
Kurt
http://pure-gas.org/
WhiskeyVictor36(at)aol.co Guest
Posted: Thu Jul 22, 2010 7:57 pm Post subject: MidValleyA/P: Good Gas |
Kurt,
Thank you very much for posting that Ethanol Free Gas site. NJ state law prevents any gas stations from selling Ethanol Free gas. But Pennsylvania law does allow it and I have found one station within 60 miles. I passed the info on to my friends at EAA Chapter 216 - South Jersey. Already two fellows have gone there and purchased gas and a couple more are getting tanks set up to do the same. So, thank you again for this information.
Bill Varnes
Original FireStar
Audubon, NJ
In a message dated 7/16/2010 6:20:46 P.M. Eastern Daylight Time, frank.goodnight(at)att.net writes:
| Quote: | Many of you probably know of this site already, but I just ran across it. It lists ethanol free gas stations by state.
Kurt
Eugene Zimmerman
Posted: Fri Jul 23, 2010 1:50 pm Post subject: MidValleyA/P: Good Gas |
Hey Guys,
Just a heads up on "Ethanol Free Gas".
A flying buddy of mine was using regular 87 octane for hundreds and hundreds of hours and recently decided to try some of that gas advertised as "Premium Ethanol Free Gas". He immediately experienced engine problems with cyl head temps spiking dangerously high while egt temps remained in the normal range and a near engine out with forced emergency landing. Trailered the plane home and did all kinds of checks with repeated engine run-ups, each with similar symptoms and results.
He finally removed all the "Ethanol Free" fuel and refueled with his normal regular 87 octane,,,,,, and wouldn't you know it ,,,,,, it ran perfectly as it always had for hundreds of hours.
My uninformed PERSONAL opinion is that whatever the refineries are currently using instead of ethanol to meet octane specs is far worse than ethanol, at least for Rotax 503 air cooled engines. One observation we made was tiny tiny beads of some residue stuck to the plugs. Our theory is that they acted as tiny glow plugs and seemed to be causing detonation at higher power settings.
Gene Z
Regardless ,,,,, based upon my personal observation of this phenomena, I WILL NOT use "Premium Ethanol Free Gasoline" in my plane.
Gene Z
On Jul 22, 2010, at 11:57 PM, WhiskeyVictor36(at)aol.com (WhiskeyVictor36(at)aol.com) wrote:
| Quote: | Kurt,
Bill Varnes
Original FireStar
Audubon, NJ
In a message dated 7/16/2010 6:20:46 P.M. Eastern Daylight Time, frank.goodnight(at)att.net (frank.goodnight(at)att.net) writes:
Kurt
aoldman(at)xtra.co.nz Guest
Posted: Sun Jul 25, 2010 2:12 am Post subject: MidValleyA/P: Good Gas |
Many years ago, I also had the same problem of small balls fouling the plugs { this was on 2 cycl motor bikes } The solution turned out to be the oil and its mix ratio . Also one brand of petrol seemed to have the problem more than other brands. Must say I have never had the problem with fresh lead free fuel of any brand . Down her we have not gone to ethanol fuels yet { or not that they will admit to} I believe our fuel to be of poor quality and expensive at $1.76 a Ltr .
Downunder
MK111c
