				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| carl(at)flyers.freeserve. Guest
				|  Posted: Sun Jul 25, 2010 2:02 pm    Post subject: Woodcomp SR3000 |   |
				| Hi,
 Anyone have the scimitar blade version of the SR3000.
 We have just assembled ours back from the factory and the microswitch cams
 appear to be set incorrectly - we were told by Woodcomp that they had been
 set by the factory and all that would be needed was to reassemble the prop.
 The adjustment instruction sheet says the fine pitch should cut out at 18
 degrees (safety backup cut out at 17 degrees). Ours is tripping at 12.5
 degrees so significantly less than the reccomended figure. I am wondering if
 the angle settings are different for the scimitar blades as opposed to the
 normal straight ones.
 The coarse pitch switch trips at 27 degrees.
 Does anyone have experience of setting up one of these props?
 Thanks in advance.
 Carl Pattinson
 G-LABS
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| Ivor Phillips
				|  Posted: Sun Jul 25, 2010 11:25 pm    Post subject: Woodcomp SR3000 |   |
				| I have set mine to 20.0 and 19.5 respectively with coarse being 28.0,
If you set the fine pitch to give you 5200 rpm static that should put you in the ball park,
 Graham Smith of Sprite aviation can give you any technical help on
 Sprite Aviation Services Ltd
 Inglenook Farm, Roman Rd,
 Maydensole, Nr Dover
 Kent, CT15 5HP
 Tel: 01304 827266
 Mob: 07973 254615
 graham(at)spriteaviation.co.uk (graham(at)spriteaviation.co.uk)
 ivor
 On 25 July 2010 23:01, Carl Pattinson <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)> wrote:
 [quote]--> Europa-List message posted by: "Carl Pattinson" <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)>
 Hi,
 We have just assembled ours back from the factory and the microswitch cams appear to be set incorrectly - we were told by Woodcomp that they had been set by the factory and all that would be needed was to reassemble the prop.
 The adjustment instruction sheet says the fine pitch should cut out at 18 degrees (safety backup cut out at 17 degrees). Ours is tripping at 12.5 degrees so significantly less than the reccomended figure. I am wondering if the angle settings are different for the scimitar blades as opposed to the normal straight ones.
 Thanks in advance.
 http:=====
 http://forums.mle, List Admin.
		| Back to top |  |
		| josok-e
				|  Posted: Sun Jul 25, 2010 11:53 pm    Post subject: Woodcomp SR3000 |   |
				| Hi Carl,
 There were scimitar blades on mine.
 The prop had been repaired at the factory, and arrived assembled.
 I never checked the fine pitch again, which nearly cost me my life,
 because it must have been too fine to stay airborne.
 So once more, please be very careful and never fly in rain with one of
 those, because that too fine pitch, combined with a short circuiting
 microswitch will bite you.
 Apart of mine, in the small circle i am aware of, i know of 2 cases of
 shorting microswitches, one loose gearwheel on the motor (rendering the
 blades to roam on their own.) and now pitch inaccuracy confirmed.
 Wish you luck, you will need it!
 Jos Okhuijsen
 Carl Pattinson <carl(at)flyers.freeserve.co.uk> kirjoitti Mon, 26 Jul 2010
 01:01:12 +0300:
  	  | Quote: |  	  | <carl(at)flyers.freeserve.co.uk>
 Hi,
 Thanks in advance.
 Carl Pattinson
 G-LABS
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
