Arksey(at)aol.com Guest
Posted: Sun Aug 01, 2010 6:37 pm Post subject: Gearbox friction torque, when and how and it's mandatory! |
RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com>
Hi all, I hope this helps.
I thought I would talk about the gearbox friction torque and when it needs to be done and how.
It is a mandatory check every 100 hrs or the Annual and it only takes a few minutes
Roger,
thanks for posting this information....was just talking with a pilot the other day about the gearbox check....we plan on doing it to the 912 on the kolb mk lll in the near future....doing a lot of flying up here in michigan, seems everyone is getting interested....just wanted to thank you for all you do to help people with information regard the Rotax engines on this list....everyone fly safe...jim swan
FIRESTAR ll 503 Michigan jswan
GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825
ph. 517-663-8488
Roger Lee
Posted: Sun Aug 01, 2010 7:44 pm Post subject: Re: Gearbox friction torque, when and how and it's mandatory |
Hi Jim,
Thanks.
If you need any thing let me know.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
hgmckay
Posted: Mon Aug 02, 2010 9:54 am Post subject: Gearbox friction torque, when and how and it's mandatory! |
Roger, You might clarify this a bit by mentioning that this is done only on
those gear boxes that have a "slipper clutch". Many 80 hp 912 UL engine do
not have slipper clutches.
Hugh McKay
Sent: Sunday, August 01, 2010 3:38 PM
To: <rotaxengines-list(at)matronics.com>
Subject: Gearbox friction torque, when and how and it's
mandatory!
to be done and how.
few minutes, but it is very important. It has a place on the Rotax
inspection check list to record your test info and should be logged in
your logbook for the inspection. (The owners that come to me, don't bother
to look in the book, it's there.B))
You will need a set of metric allen wrenches and a fish scale. Something
that reads between 0-50 lbs. Don't use something that read really high as
it won't be accurate down at the bottom numbers where we want to measure.
I use a digital fish scale. You will need a piece of string too.
As far as the how to perform this check, well let's take a look.
While you have the prop spinner off for the inspection is a good time to
do this. First remove the M8x20 plug screw for the locking pin . It is
located about 3.5" above the magnetic oil plug. It is gold colored and has
an upward angle on the head. It is a number 5 or 6 allen screw. Remove it.
Get the black 1 3/4" crankshaft locking pin out of the Rotax orange tool
kit. We will need to rotate the prop which can be done with one plug out
of each cylinder or they can be left in. You will need a flash light to
find the crankshaft locking pin grove. You are going to shine the light
down the hole where you just took out the screw where the locking pin will
be inserted. Slowly rotate the prop counterclockwise while looking in the
hole. You may only see blackness, keep rotating until you see a shiny
smooth oily surface. Continue to rotate slowly and you will see what looks
like a notch or a "V". If you continue it will be shiny smooth again. Stop
and go back to that "V" or notch. Mo!
ve the prop back and forth slightly to get it centered. Now take the
locking pin and screw this in. It should stop with 3/4" still sticking
out. Hold the prop and slightly wiggle it while you snug up the locking
pin into the center of the notch. Now your crankshaft should be locked.
Absolutely do not screw the locking pin in further if it just keeps going.
That means you missed. Take it out and look for the smooth oily surface
and notch again. This is very easy so don't worry.
Now with the crankshaft locked the prop can still move approximately 30
degrees. Push the prop back all the way counterclockwise until it stops.
Take a tape measure and measure out from the center of the prop hub
outward along the blade between 24-30 inches. It doesn't matter what
number you pick. If you pick 26", 28" or 30" it doesn't matter. Put a
little pencil or a mark at your measurement.
You need your string now around the prop at your mark. Now take your scale
and hook it on the string. In a nice straight and even pressure pull, pull
the scale and prop. Watch how much the scale reads. I usually do this 2-3
times to make sure my reading is accurate. So let's say your reading was
17 lbs. To find the torque measurement we take that number 17 lbs. and
multiply it times the number of inches you measured out from the prop
center. Let's say you used 28" and had a 17 lb pull. 28 X 17 = 476 in/lbs
That is a good number and is the number to record on the Rotax inspection
sheet. We look for a bottom number of 300 and the high end of 530 in/lbs.
In this case the higher the better. If you are at 490 in/lb verses 340
in/lb you are much better off. No it isn't worth the effort to pull the
gearbox to go from 450 to 510 and getting the friction right on is not an
exact science. It is accomplished by pulling the gearbox and using shims
to add more pre-load to the bellville washers that act as our spring
tension.
Your done, take out the locking pin and don't loose it. replace the plug
screw at
133 in/lbs torque.
If you are a member of the R.O.A.N. website you can look at this video
that demonstrates this very well.
Hi all,
to be done and how.
an upward angle on the head. I believe it is a number 6 allen screw.
Remove it. Get the black 1 3/4" crankshaft locking pin out of the Rotax
orange tool kit. We will need to rotate the prop which can be done with
one plug out of each cylinder or they can be left in. You will need a
flash light to find the crankshaft locking pin grove. You are going to
shine the light down the hole where you just took out the screw where the
locking pin will be inserted. Slowly rotate the prop counterclockwise
while looking in the hole. You may only see blackness, keep rotating until
you see a shiny smooth oily surface. Continue to rotate slowly and you
will see what looks like a notch or a "V". If you continue it will be
shiny smooth again. Stop and go back to that "V" or notc!
h. Move the prop back and forth slightly to get it centered. Now take the
tension.
screw at 133 in/lbs torque.
http://rotax-owner.com/index.php?option=com_content&view=article&id=60:friction-torque&catid=8:training&Itemid=174
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=307071#307071
Roger Lee
Posted: Mon Aug 02, 2010 11:04 am Post subject: Re: Gearbox friction torque, when and how and it's mandatory |
Hi Hugh,
Your right, I just assumed people would know, I should have been a little more specific.
Tucson, Az.
Cell 520-349-7056 |
