POINTY HEADED FAA ADMINISTRATORS
Goto page 1, 2, 3  Next
Frank
PostPosted: Tue Jan 10, 2006 6:09 pm    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Yakkers;
I'm asking WHY should some of us be "Grandfathered" into no flight
restrictions for Experimental Exhibition registered aircraft
(pre-moratorium) and others with the exact same plane be limited with FAA
restrictions like the no flight past a 300 mile limit rule? What the hell
were these pointy headed FAA bureaucrats thinking? Where do they get off
letting some have all the freedoms they want while restricting others? It
seems like an unacceptable and unequal application of the law. I seem to
remember somewhere that all laws have to be equally administered or they are
unconstitutional. And why put that restriction on us anyways? What pointy
headed bureaucrat thought of that one and why? I suggest we, as RPA members,
use our clout to get rid of this unconstitutional and bullshit set of
regulations!
Frank
"All proficiency/practice flights shall be conducted within the geographical
area described in the applicant's program letter and any amendments to that
letter, but that area will not exceed 300 nautical miles of the aircraft's
home base airport. An exception is permitted for proficiency flying outside
of the area stated above for organized formation flying, training, or
checkout in conjunction with a specific event listed in the applicant's
program letter (or amendments). The program letter should indicate the
location and dates for this proficiency flying."
OOOHHHH............But if you're "grandfathered" and one of the "special
ones" you don't have to do this even though you own the exact same airplane.
What a crock of shit these bureaucrats have done to us! What the hell gives
them the right to unilaterally declare the exact same planes different? F'in
bastards!
L39parts(at)hotmail.com
PostPosted: Tue Jan 10, 2006 8:10 pm    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
brian
PostPosted: Tue Jan 10, 2006 9:00 pm    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Frank Haertlein wrote:
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
Frank
PostPosted: Wed Jan 11, 2006 2:58 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Yakkers
AOPA......................
EAA.......................
NRA.......................
Warbirds of America ......
CJAA .....................
The Sierra Club ..........
CRPA .....................
AARP .....................
AMA ......................
AFL-CIO ..................
Sport Fisherman's Assoc...
American Hunter...........
NOW.......................
And a thousand other organizations.........
All have political representation to look out for their interests.
RPA grant.txt
Vote in the following poll
http://forums.matronics.com/viewtopic.php?t=776
If your warbird is more than 800 horsepower you may only take off and land
from your home airport.
If your warbird is a jet you may only take off and land from your home
airport.
You may not operate your aircraft more than 300 nautical miles from your
home airport.
You must submit a program letter every year.
To deviate from the above you must FAX the FAA for each instance.
These are actual FAA rule. I'm asking what FAA genius thought them up and
why?
Don't you want to change stupid rules like these?
dabear(at)damned.org
PostPosted: Wed Jan 11, 2006 5:22 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Frank,
You are very funny.
AOPA has over 300,000 members. They are one of the biggest "aviation
lobby" organizations. A key part of their lobby agenda is to get rid of
pop up TFRs and reduce/eliminate the ADIZ around DC. Now they are about
1% of the US population and they can't get movement.
RPA has approximately 300 members. We are about 0.000001% of the US
population. If you think we have ANY real lobby power with the federal
government, (without a couple million to buy a few congress critters),
you have received a serious head injury and you should immediately seek
advanced medical care. I don't know anyone who has a warbird, that
likes the current program letter issue, however it really isn't a big
deal to comply and fly where ever you want (For those non-jet warbirds)
by just sending the FAA a fax.
DaBear
Yakkers
RPA grant.txt
airport.
home airport.
why?
gus.fraser(at)gs.com
PostPosted: Wed Jan 11, 2006 5:31 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Fax, come on this is the 21st century, I send an email.
Gus
pilot8kcab(at)hotmail.com
PostPosted: Wed Jan 11, 2006 5:58 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Frank,
I've thought about this subject a few times as well and thought the approach
for a rectification would be coming at it from a different angle. Bear with
this logic for a second. The EAA as with AOPA has had a hard time
convincing the powers to be that a medical is of little benefit for the
majority of non-commercial pilots out there, despite overwhelming evidence
in their favor. Getting the FAR's changed to remove medical requirements as
with your suggestion would be a major uphill battle. Part of the end around
approach is the new EAA Sport Pilot certificate which does not require a
pilot medical (with a few caveats). Now part of the idea is that a database
of evidence with time will be built under this new pilot certificate which
can be added to the database of evidence from the glider pilot sector, that
there is no difference in accident rate (caused my medical incapacitation)
between the medically certificatied pilot population and the non-medically
cetificated pilot population. Presumably backed with this evidence the
EAA/AOPA will have more clout in getting the Class III medical requirement
removed from the private pilot certificate.
Now using a similar approach, I would propose that instead of trying to
remove the current requirement that instead an effort be made to create
another Experimental category, perhaps "Experimental Proven". The
"Experimental" wording should bring the interest of the EAA. The new
category could use the rational that if an aircraft or perhaps aircraft type
has been inoperation without major structural incident for "X" number of
years then the design inherently by trial has proven itself and does not
need to go thru the rigirous FAA certication process etc. I would suggest
that after "X" number of years has passed, that anything in the
"Experimental Exhibition" category could be converted to the proposed
"Experimental Proven" category, and that the new category have no
restrictions beyond those in the Experimental Home Built category. My
thinking is that the EAA has experience pushing new certificates into
reality and perhaps that approach can be used to push a new Experimental
certification category into existance.
Regarding the need for the current rules, it has always been my take that
the rules were written not so much for safety reasons (which is the FAA's
charter) but instead to protect the current manufactures of US certified
aircraft from a flood of lower priced well designed aircraft from entering
the market and essentially putting them out of business. Want an example
(non-russian sorry), the Edge 540 is (arguably I'm sure by some) at the
moment the best and strongest unlimited aerobatic aircraft produced in the
USA and possibly the world. It's owners are flying under the "Experimental
Exhibition" category. The new price for an Edge 540 is far less than its
nearest "Certificated" competitor and if the "Experimental Exhibition" rules
were relaxed to those of the pre-moritorium aircraft, that certificatied
competitor would have a very tough time selling any aircraft with such a
cost differential. The same would hold true for the importation of the Yaks
etc.
Scott
dsavarese(at)elmore.rr.co
PostPosted: Wed Jan 11, 2006 6:01 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Really Ron? What does the FAA Order 8130.2F (or its predecessors) say with regards to "..you can go anywhere you want if you put it on your program letter or fax the FSDO." Are you saying that if you want to go visit your grandmother and she lives outside of your 300 NM proficiency area, all you have to do is either have "going to visit my grandmother in Anytown, USA" on you annual program letter or send a FAX to your FSDO saying "going to visit my grandmother in Anytown, USA"?
Dennis
cgalley(at)qcbc.org
PostPosted: Wed Jan 11, 2006 6:36 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Sometimes it would pay to keep one's mouth shut. If the FAA sees too much of this kind of talk, they might decide to "standardize" things by requiring that all the pre-moratorium airplanes get recertificated to the new rules. They definitely won't allow the new certifications to regress to the old rules!
The new certifications were brought about primarily by people bringing all the soviet bloc jets into the country. In fact, the sheer number of airplanes in the exhibition category in recent years prompted the FAA to refine the certification of these aircraft.
jon(at)email.net
PostPosted: Wed Jan 11, 2006 6:41 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
The stuff they did doesn't have any teeth in it anyway... with the jets
and the 800hp+ stuff, you can go anywhere so long as you let them know
you're going -- the wording says "notify". It doesn't say that they have
to approve or even acknowledge the notification. I need 48 hours notice
to go somewhere that's not on my annual program letter, but apparently I
can modify that program letter on NO notice, say even from a Blackberry
while on short final.
Many people in the FAA are also wondering what good all this clearly "make
work" paperwork does... I've been told that it will be "going away", but a
time frame is never given.
Jon
jon(at)email.net
PostPosted: Wed Jan 11, 2006 6:47 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
You know what happenend? "They" got together in a back room at AirVenture
about 12 years ago and the FAA said "We don't want these soviet jets
galavanting all over the country -- somebody make some rules to throw a
wrench in that." And so some arbitrary rules were agreed to by the
parties attending.
The jets have a 600nm limit on them... but there are jets everywhere --
there's not a single spot of ground in the CONUS that's not within 600nm
of some jet, so it did NOTHING in terms of safety. It did, however, calm
Cessna's fears about having to compete with cheap, well-built jets.
Jon
brian
PostPosted: Wed Jan 11, 2006 6:58 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Fraser, Gus wrote:
Brian Lloyd
brian
PostPosted: Wed Jan 11, 2006 7:08 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
That is brilliant Scott! As I pointed out, you can't get a bureaucracy
to change its mind on something it has done in the past and then written
down. (Evidence: Bob Hoover.) But what you are proposing is new ruling
and new paper! That let's them off the hook.
that the rules were written not so much for safety reasons (which is the
FAA's charter) but instead to protect the current manufactures of US
certified aircraft from a flood of lower priced well designed aircraft
from entering the market and essentially putting them out of business.
That strikes me as correct. The rumor I heard about the current change
(post "moratorium") came about because Cessna was in fear of loss of
Caravan sales to the AN-2.
Want an example (non-russian sorry), the Edge 540 is (arguably I'm sure
by some) at the moment the best and strongest unlimited aerobatic
aircraft produced in the USA and possibly the world. It's owners are
flying under the "Experimental Exhibition" category. The new price for
an Edge 540 is far less than its nearest "Certificated" competitor and
if the "Experimental Exhibition" rules were relaxed to those of the
pre-moritorium aircraft, that certificatied competitor would have a very
tough time selling any aircraft with such a cost differential. The same
would hold true for the importation of the Yaks etc.
OTOH, market forces would prevail. The price of the Edge 540 would go up
because the cost of certification would have to be added into the cost
of the airplane. Also its perceived value would go up so it could demand
a higher price. Its price would come into line with domestic competitors
and there would be a level playing field rather than a market skewed by
government meddling.
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
Brian Lloyd
brian
PostPosted: Wed Jan 11, 2006 7:11 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
A. Dennis Savarese wrote:
<dsavarese(at)elmore.rr.com>
Brian Lloyd
brian
PostPosted: Wed Jan 11, 2006 7:14 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
cgalley wrote:
Brian Lloyd
PostPosted: Wed Jan 11, 2006 8:04 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
My sent box and that of my email provider are a better source of
confirmation. If a fax is required then the regs should say that if they
don't specify a contact method they don't have a leg to stand on.
My FSDO is Teterboro, allegedly the worst behaved in the country, not my
words they are great with me. Trust me, the last thing these guys want to do
is have even more paper to file. Amongst other things they are human and as
such hate paperwork that they have to do.
To Frank,
As far as the regs go I have never seen it as a problem. This is the break
down as given to me by an FAA AW guy.
"You can fly for three reasons
1. Maintenance
2. Exhibition
3. Proficiency
Any flight that you do as PIC is, above all else, a contribution to your
proficiency."
And that was from the FAA !
Frank please remember there is a big old world out there and, if you
recognize it or not, here in the US we enjoy THE most freedom regarding
experimental aircraft, anywhere in the world.
I would agree that personal responsibility should be the overriding factor
in how we fly but the regs exist and they are what they are. If you don't
believe me just ask the British subscribers what it is like dealing with the
Campaign Against Aviation (commonly called the CAA).
It's kind of like sitting on the beach with a tequila and a hot chick and
complaining about the crabs.
Gus
PostPosted: Wed Jan 11, 2006 8:09 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
The operative word is "exhibit". From 8130.2F Change 1, "A certificate for experimental exhibition must only be issued when an aircraft is to be used for valid exhibition purposes. Included in those purposes are organized airshows, organized air races, organized fly-in activities, organized exhibitions, youth education events, shoppingmall/school/similar static displays, organized aerobatic competition, sail plane fly-ins or competitive races or meets, and movie or television productions."
Yes, Brian you're correct about being careful. But being careful does not equate to "you can fly it anywhere you want by sending a FAX to your FSDO." Proficiency flying is within your 300 NM limitation. Outside of the 300 NM proficiency area, you are <suppose> to be attending a formal event such as a fly-in, airshow, etc.
Does everyone comply with this? Heck no. The point is simply if you're outside of your 300 nm proficiency area, be sure you're covered. Is it a dumb rule? You bet. But it's still the rule under which our aircraft are certificated.
FWIW
Dennis
brian
PostPosted: Wed Jan 11, 2006 8:37 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
Fraser, Gus wrote:
Brian Lloyd
cgalley(at)qcbc.org
PostPosted: Wed Jan 11, 2006 8:44 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
You well may be right, but how to you answer your wife's question... Do these make me look FAT? If you answer truthfully, you might piss off your wife! If you rattle the cage so to speak, you might piss off the others in the group when "they" decide to make everyone the same and take away the grandfathered permissions.
Since they control the rules, then the effort to change must be done with diplomacy and tact. Name calling doesn't promote good relationships.
jon(at)email.net
PostPosted: Wed Jan 11, 2006 10:05 am    Post subject: POINTY HEADED FAA ADMINISTRATORS Reply with quote
What spirit?
The problem with 8130.2x is that it has a hidden agenda. When you don't
spell out the intent of your rules (because spelling it out would make
clear that you're up to monkey business) you wind up with rules with lots
of loopholes.
They tried to tack things down all around the edges instead of coming
right out and saying, "These rules are intended to hobble and
inconvenience."
So I don't think that stopping by your grandmother's violates the spirit
of the rule -- since nobody really knows what that spirit is. And I don't
take hints. Smile
Jon
No silly. That would be against the spirit of the rule. OTOH, if you are
careful about where you exhibit the airplane or fly it for proficiency
it is amazing how convenient it can be to stop off and see your
grandmother along the way.
Page 1 of 3
