jaycwik(at)gmail.com Guest
Posted: Fri Aug 06, 2010 8:23 am Post subject: IO-540 Available |
Although I thought I was sending the previous message to Tom, The question is probably better put to the group anyway.
On Fri, May 15, 2009 at 10:42 AM, <tom.on.the.road(at)juno.com (tom.on.the.road(at)juno.com)> wrote:
[quote]--> RV10-List message posted by: tom.on.the.road(at)juno.com (tom.on.the.road(at)juno.com)
Guys & Gals,
I have a beautiful IO-540 that has 100 smoh & 800 snew (new cylinders,
9.5:1 pistons, & crankshaft). This engine was removed from a Lancair,
has 260+ HP and runs very smooth. It has two new alternators, prop
governor, oil cooler, starter, and mags. Warranty. I have pics.
It needs a home in an RV-10.
Tom Lawson
970-420-1798
Compete with the big boys. Click here to find products to benefit your business.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTI97wbFvxKUy6Xc96f8HQkjej3raEo40wd4VbZF2uJoOxeixDypeY/
bscription,
www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Hi Tom
If you recall, I bought this engine from you, spring of '09. I've had it pickled and will be hanging it on the plane very soon.
I was looking at a Hartzell HC-E2YR-1BF prop (now sold) on line and realize I don't know where to go to know how to match up a prop with the engine. I suppose if I buy new I'll go with the prop Van's sells for their 10's which is a C2YR-1BF.
However, do you know a reference, resource or way of knowing what used or rebuilt props would be a good match for this engine and RV-10? Do you know what the Lancair had on it where the engine came off of?
thanks - Jay
Guys & Gals,
Tom Lawson
970-420-1798
bscription,
bruce1hwjohnson(at)yahoo. Guest
Posted: Fri Aug 06, 2010 11:55 am Post subject: IO-540 Available |
Hello All
I have a James cowl that I decided not to use. If anybody has interest I wll let it go for $1000.00
Bruce 602-291-1011
Sent: Fri, August 6, 2010 9:20:03 AM
Subject: Re: RV10-List: IO-540 Available
Hi Tom
thanks - Jay
Guys & Gals,
Tom Lawson
970-420-1798
bscription,
[b][b]
