imap8ntr(at)cox.net Guest
Posted: Sat Aug 07, 2010 8:19 pm Post subject: "MAG" Check |
The Jab engine manual has all these operating limitation parameters. I do
my mag check at about 2000RPM and the drop parameters I think are less than
100RPM drop and less than 100 from side to side. This is from memory but I
know the manual states these figures. I have these figures printed in my
engine run up checklist. I never get a carb heat drop unless there is some
icing in the carburetor. Not exactly sure why but I think it has something
to do with the Bing being set up as "altitude compensating."
Ivan
Phoenix, AZ
Clive J
Posted: Sun Aug 08, 2010 2:35 am Post subject: "MAG" Check |
The Jab engine doesn't drop like a Lycoming when you earth one side.
It's more of a sensation than a drop, on an analogue tach it's only a
quiver on the needle.
Something to do with spark plug positions I imagine. On a big ole gas
guzzler they are a lot further apart.
The carb heat again doesn't do much on the ground, both tests show a
little more clearly in the air.
I usually use 1800 as well to answer your question.
Regards, Clive
JohnDRead(at)AOL.COM Guest
Posted: Sun Aug 08, 2010 9:48 am Post subject: "MAG" Check |
Hi Guys;
I recall from the Jabiru installation instructions the carb heat is always on so there should not be any RPM drop.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 8/7/2010 10:19:51 P.M. Mountain Daylight Time, imap8ntr(at)cox.net writes:
| Quote: | --> JabiruEngine-List message posted by: "Ivan" <imap8ntr(at)cox.net>
Ivan
Phoenix, AZ
----- Original Message -----
To: <jabiruengine-list(at)matronics.com>
Sent: Saturday, August 07, 2010 8:28 PM
Subject: "MAG" Check
| Quote: | --> JabiruEngine-List message posted by: "MHerder"
<michaelherder(at)beckgroup.com>
What RPM are you doing your "Mag" Check at? What's a normal drop? I was
trying 1800 RPM and am not getting a noticable drop, also not getting a
noticeable drop when I kick in the carb heat?
Engine has about .9 hr of ground run time on it and we're still working
out some kinks.
I guess we call a "mag" check a coil or orgnition check on a Jab?
I'm using the Grand Rapids EIS and noticed that there are two sensitivity
settings on the tach, but I want to get some go no go parameters from some
folks.
One Rivet at a Time!
http://forums.matronics.com/viewtopic.php?p=307893#307893
========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
jcrowder(at)lpbroadband.n Guest
Posted: Sun Aug 08, 2010 10:25 am Post subject: "MAG" Check |
Not on mine. I am finishing my 3300 install and my air box has a diverter flap controlled by a push/pull cable I have installed.
Jim Crowder
Installing a 3300 in a Kitfox 5
Northern Colorado
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of JohnDRead(at)aol.com
Sent: Sunday, August 08, 2010 10:47 AM
Subject: Re: "MAG" Check
Hi Guys;
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
Ivan
Phoenix, AZ
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sun Aug 08, 2010 2:48 pm Post subject: "MAG" Check |
Try your mag check at different, typically lower, rpms- 1100-1300 range will normally result in 10-30 rpm drop. Try it at idle or in cruise flight and it's pretty obvious as well. You should also be able to hear a change in engine sound even if no evidence showing on tach...
Possum
_________________ From The PossumWorks... |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Aug 09, 2010 11:29 am Post subject: Re: |
As to no RPM drop with carb heat application on the ground, I ditto that. I believe the low amount of air running over the heat muff helps cause this. You will notice an RPM reduction if flight with carb heat once you get flying.
Good luck,
_________________ David Gallagher
Cincinnati, OH area |
Kayberg(at)aol.com Guest
Posted: Mon Aug 09, 2010 11:52 am Post subject: "MAG" Check |
In a message dated 8/9/2010 3:30:51 P.M. Eastern Daylight Time, david.m.gallagher(at)ge.com writes:
| Quote: | --> JabiruEngine-List message posted by: "DaveG601XL" <david.m.gallagher(at)ge.com>
Good luck,
Because the spark plugs are only a couple inches away from each other, there will be very little mag drop. Some of us have flown WITHOUT carb heat for several years, so dont expect too much from that either.
In short, it is not a Lycon engine with the plugs on opposite sides of the cylinders, nor does it have an ice-making venturi carb like the Marvel-Dribbler or Strombad.
I just check the switches while taxiing out and note if it is revving up on takeoff. If the one mag is not working, you will find it out quickly when you hit the switch, but you can have a dead one in the air and not know it.
IMHO
Doug Koenigsberg
checkpoint2(at)comcast.ne Guest
Posted: Mon Aug 09, 2010 12:07 pm Post subject: "MAG" Check |
I concur completely after 250 hours on MOGAS Jabiru. Bob Haas.
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Kayberg(at)aol.com
Sent: Monday, August 09, 2010 3:52 PM
Subject: Re: JabiruEngine-List: Re: "MAG" Check
Good luck, |
IMHO
Doug Koenigsberg
| Quote: | | http://www.matronics.com/Navigator?JabiruEngine-List | 0123456789
