Low RPM J3300
peterthomson
PostPosted: Mon Aug 09, 2010 6:59 am    Post subject: Low RPM J3300 Reply with quote
A friend recently adjusted the throttle linkage on his Corvus/Jabiru
3300, and now finds he can't get above 2400RPM (previously 2900). He
says the carb opens fully to the stop, and the butterfly is wide open.
The RPM readout is steady, not erratic for any RPM on his Dynon. He
has not been able yet to verify the RPM independently.
Any experiences here ?
thanks
Peter
CZAW CH701SP / 912ULS
dons701
PostPosted: Tue Aug 10, 2010 7:05 am    Post subject: Re: Low RPM J3300 Reply with quote
Hi Peter,
Any details as to what was done to "adjust" the linkage? What was the issue with how it was running that required the change?
Don
Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop
