		Kelly McMullen
				 Posted: Fri Aug 13, 2010 8:04 am    Post subject: Prop Governor revisited |
				In reviewing the archives, I note that several times it was pointed
 out that Vans supplies a governor setup for the narrow deck Lycoming
 engine configuration, when most   folks are using are wide deck
 engines that should get different dash number set for that engine. Is
 it worth deleting the Vans unit from the FWF kit and obtaining the
 correct one elsewhere, or are folks satisfied with repositioning the
 arm and resetting the max rpm on what Vans provides?
A&P/IA, EAA Tech Counselor
KCHD |
		bcondrey
				 Posted: Fri Aug 13, 2010 8:23 am    Post subject: Prop Governor revisited |
				As long as you have at least Rev F of the governor supplied by Vans you'll be fine.  Revisions prior to that potentially have an issue with surging.  I would imagine that anything you get delivered now will be latest revision.  If others are reading this and they have an older Rev B or C prop governor, MT will update it to latest version without charge if you have issues.
 Bob
 RV-10 N442PM
		lessdragprod(at)aol.com Guest
				 Posted: Sat Aug 14, 2010 2:46 am    Post subject: Prop Governor revisited |
				I believe the question being asked is "Is only getting 2550 RPM maximum acceptable when a (I)O-540 narrow deck governor is installed on a (I)O-540 wide deck engine".
    I wouldn't think so.
    Especially when Van's Aircraft could provide the correct governor.  I am aware of them knowing about this for at least three years.
  Just my opinion.
    Jim Ayers
    RV-3 sn 10050 650 hours - LOM M332A engine - 3 blade electric CS MT Propeller & Warne fixed pitch propeller
    RV-6A sn 21873 150 hours - Lyc. O-360 engine - metal 2 blade CS MT Propeller & 3 blade CS MT Propeller
    RV-4/HR2/modified sn 001 28 hiours - IO-540 narrow deck engine - counterweighted 4 blade CS MT Propeller & counterweighted 3 blade CS Propeller in process.
		hotwheels
				 Posted: Sat Aug 14, 2010 5:48 am    Post subject: Re: Prop Governor revisited |
				Stuff that keeps me up at night.
 Does anyone have pointers to links or threads that describe how to tell if one has Rev F? I looked over the MT docs in my possession, but didn't get a sense of rev number (could have missed it tho). My serial number ends in an "F"... Maybe that's good?
 Jay
  	  | bcondrey wrote: | 	 		  As long as you have at least Rev F of the governor supplied by Vans you'll be fine.  Revisions prior to that potentially have an issue with surging.
		bcondrey
				 Posted: Sat Aug 14, 2010 6:11 am    Post subject: Prop Governor revisited |
				You're good then.
 Bob
