ricklach
Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
elleryweld(at)aol.com Guest
Posted: Tue Aug 10, 2010 4:35 pm Post subject: 912 17mm Water Hose Again |
Rick
I have gone to CarQuest and Purchased Molded hose for this same problem you might have to go out back and go through there hoses department to find what your looking for and maybe buy some longer hoses and cut them off to get them to where you want them go
Ellery Batchelder Jr.
Roger Lee
Posted: Tue Aug 10, 2010 5:18 pm Post subject: Re: 912 17mm Water Hose Again |
Call California Power Systems (CPS) and ask for Jeremy McGregor. Tell him I sent you. He should get you taken care of. 510-357-8192
He does not work Fridays and comes in at 1000 hrs. Monday thru Thursday.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
rickofudall
Posted: Tue Aug 10, 2010 6:52 pm Post subject: 912 17mm Water Hose Again |
I use silicone hose from either Sport Hoses
http://www.sporthoses.com/parts/
or Pegasus Racing.
http://www.pegasusautoracing.com/advcat.asp?CategoryID=COOLING
Either has every shape and reducer you could want, Pegasus has more components in addition to the hose. Both give fine service.
Rick Girard
On Tue, Aug 10, 2010 at 6:23 PM, ricklach <rick(at)ravenaviation.us (rick(at)ravenaviation.us)> wrote:
[quote] --> RotaxEngines-List message posted by: "ricklach" <rick(at)ravenaviation.us (rick(at)ravenaviation.us)>
I know we have had this conversation before, but I’m hopping for some new information. I need to replace the eight 17MM water hoses that go from the water pump to the heads on the bottom of the engine and then from the heads on the top to the water tank on the 912 engine. I know that some people have used ¾ inch hose but I’m not comfortable with it because it’s a little big. Has anyone found a source for real 17mm hose for this application?
701Driver
N35 26.700, W118 16.743
http://forums.matronics.com/viewtopic.php?p=308297#308297
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Dick Maddux
Posted: Wed Aug 11, 2010 3:49 am Post subject: 912 17mm Water Hose Again |
Rick
I recently replaced my hoses and had the same dilemma as you. I finally bite the bullet and bought my 17mm hoses from Lockwood (1 length) the molded piece I matched at NAPA. It was expensive but like you, I wanted to use the right parts as much as I could.
I couldn't find 17 mm hose anywhere in the US but Rotax dealers.
Dick Maddux
Milton,Fl
912UL
