tgesele(at)optonline.net Guest
Posted: Mon Aug 16, 2010 8:49 am Post subject: Nosewheel Fairing Alignment |
Stumbled onto an interesting observation. Discovered after adding all
the wheel fairings, the -10 required right rudder at high cruise speeds.
After damaging and removing the nosewheel fairing, I no longer needed to
hold right rudder at any speed (true airspeed 2 knots slower than with
the fairing at high speed cruise). Since nothing else on the plane has
changed, I'm assuming the prop blast is pushing the nosewheel out of
trail. Has anyone else had a similiar experience, have any suggestions
on a way to slightly re-orient the nosewheel fairing to minimize the
effect, or can come up with a different explination?
Tom Gesele - N629RV
Posted: Mon Aug 16, 2010 8:58 am Post subject: Nosewheel Fairing Alignment |
My Grumman (same type of nose gear setup) points off to the right .....
and yes, it looks funny .... but I doubt that's causing the right rudder
problem. However, I can't explain why the removal of the wheel pant
would 'fix' the problem. The wheel pant doesn't have any effect on the
rigging of the Grumman whether it's there or not. the only reason I
used the Grumman as an example is that I have lots of hours in it and
I'm still building the -10.
Linn
THOMAS GESELE wrote:
speeds. After damaging and removing the nosewheel fairing, I no longer
needed to hold right rudder at any speed (true airspeed 2 knots slower
than with the fairing at high speed cruise). Since nothing else on the
plane has changed, I'm assuming the prop blast is pushing the
nosewheel out of trail. Has anyone else had a similiar experience,
have any suggestions on a way to slightly re-orient the nosewheel
fairing to minimize the effect, or can come up with a different
explination?
Tom Gesele - N629RV
Posted: Mon Aug 16, 2010 9:12 am Post subject: Nosewheel Fairing Alignment |
Other than not needing the rudder in cruise are you experiencing a problem
with the fairing? the wheel, a shimmy or anything? if not leave it alone.
Call Vans and get their opinion as well.
Sent: Monday, August 16, 2010 9:48 AM
Subject: Nosewheel Fairing Alignment
Stumbled onto an interesting observation. Discovered after adding all the
wheel fairings, the -10 required right rudder at high cruise speeds. After
damaging and removing the nosewheel fairing, I no longer needed to hold
right rudder at any speed (true airspeed 2 knots slower than with the
trail. Has anyone else had a similiar experience, have any suggestions on
a way to slightly re-orient the nosewheel fairing to minimize the effect,
Tom Gesele - N629RV
dmaib(at)mac.com Guest
Posted: Mon Aug 16, 2010 2:56 pm Post subject: Nosewheel Fairing Alignment |
I have seen photo's of -10's in flight with the nosewheel cocked off
to the side a bit.
David Maib
40559
Flying
longer needed to hold right rudder at any speed (true airspeed 2
knots slower than with the fairing at high speed cruise). Since
nothing else on the plane has changed, I'm assuming the prop blast is
pushing the nosewheel out of trail. Has anyone else had a similiar
experience, have any suggestions on a way to slightly re-orient the
nosewheel fairing to minimize the effect, or can come up with a
Tom Gesele - N629RV
Robin(at)PaintTheWeb.com Guest
Posted: Mon Aug 16, 2010 4:14 pm Post subject: Nosewheel Fairing Alignment |
That was the guy the flew off half cocked.
Please Do Not Archive
Posted: Tue Aug 17, 2010 4:03 am Post subject: Nosewheel Fairing Alignment |
Thanks for the responses. I'm going to fabricate a tab and temporarily
attach to the fairing. If this has any affect, I'll post pictures of the
mod.
Tom Gesele 629RV
On Mon, Aug 16, 2010 at 6:54 PM, David Maib wrote:
to the side a bit.
David Maib
40559
Flying
explination?
Tom Gesele - N629RV
Posted: Tue Aug 17, 2010 4:55 am Post subject: Nosewheel Fairing Alignment |
You might also want to re-check the breakout force on your nosewheel.
They tend to loosen up fairly quickly when you first start flying. I
know there was some discussion on this forum a year ago (or longer)
about that being a potential cause of the nosewheel cocking to one
side during flight.
David Maib
40559
flying
temporarily attach to the fairing. If this has any affect, I'll post
pictures of the mod.
Tom Gesele 629RV
off to the side a bit.
David Maib
40559
Flying
all the wheel fairings, the -10 required right rudder at high
cruise speeds. After damaging and removing the nosewheel fairing, I
no longer needed to hold right rudder at any speed (true airspeed 2
is pushing the nosewheel out of trail. Has anyone else had a
similiar experience, have any suggestions on a way to slightly re-
orient the nosewheel fairing to minimize the effect, or can come up
Tom Gesele - N629RV
