rv10rob(at)gmail.com Guest
Posted: Mon Aug 09, 2010 7:38 am Post subject: Fuel pressure hose too long? |
Anyone else run into an issue with the fuel pressure hose being too long? The 15" hose seems ridiculously long given the short distance between the engine fitting and the firewall-mounted sender. It works a little better if I clock the 45" fitting on the fuel pump away from the firewall, but it seems like I should just get a shorter hose.
Anyone else run into this, or am I missing something?
Thanks...
-Rob
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Mon Aug 16, 2010 6:36 pm Post subject: Re: Fuel pressure hose too long? |
Yeah, mine's too long too. I just let it flop around. Will probably tie it to something after I get more stuff installed around it.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
