Posted: Tue Apr 25, 2006 5:35 pm Post subject: Hose question.... |
Folks,
I found a couple of hoses that came with my engine from Aerosport power.
They're both firesleeved -6 hoses with steel female NA-6 fittings on each end.
the only difference in the two hoses is the length 19" / 31" and the markings on the etched SS tags
From what I can see:
111F417-6S-0180
CDIQ00
Rubber PT-9-26-02
vs
111F417-6S-0300
CM36424
PT 8/11/03
They're both marked TSO C53a type C / TSO C75 type I APF
What are these for? What can I use them for? Fuel lines????
Ralph Capen
| - The Matronics LycomingEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?LycomingEngines-List |
cowboy286(at)sbcglobal.ne Guest
Posted: Tue Apr 25, 2006 5:47 pm Post subject: Hose question.... |
Sounds like Oil cooler lines or Remote oil filter lines
"Ralph E. Capen" <recapen(at)earthlink.net> wrote: Quote: | Folks,
111F417-6S-0180
CDIQ00
Rubber PT-9-26-02
vs
111F417-6S-0300
CM36424
PT 8/11/03
Ralph Capen
Posted: Tue Apr 25, 2006 5:53 pm Post subject: Hose question.... |
wouldn't they be -8 for oil cooler? I'll check to see if they'll fit though.....
I don't know - I would think the part numbers may give them away.....
Maybe I'll zap Aerosport.....
jack.byrne(at)bigpond.com Guest
Posted: Tue Apr 25, 2006 11:51 pm Post subject: Hose question.... |
The 2 lines I got with my engine were fuel lines.
1. Engine driven fuel pump to Precision Injection body.
2. Injection body to injector spider.
If yours is injected this is what they will be. Sounds like the spider is on top of the engine, that will be the 31 inch one.
Chris Byrne
Sydney
deene(at)us.ibm.com Guest
Posted: Wed Apr 26, 2006 12:39 am Post subject: Hose question.... |
Firesleeved -6's are usually fuel hoses. You didn't specify which engine you have...but if its injected, I would suspect the shorter hose is for gascolator to engine fuel pump and the longer is fuel pump to servo.
Also, on 360's, you usually see -8's on the oil cooler lines, sometimes sleeved, sometimes not.
YMMV...
And, BTW, the PT part of the tags indicate the pressure test dates...these hoses are several years old.
Deene
Sent by: owner-lycomingengines-list-server(at)matronics.com
04/25/2006 08:28 PM Please respond to
lycomingengines-list(at)matronics.com
To
"lycoming engine list" <lycomingengines-list(at)matronics.com> cc
Subject
Hose question....
Folks,
111F417-6S-0180
CDIQ00
Rubber PT-9-26-02
vs
111F417-6S-0300
CM36424
PT 8/11/03
Ralph Capen
glcasey(at)adelphia.net Guest
Posted: Wed Apr 26, 2006 3:44 am Post subject: Hose question.... |
I'll bet they are fuel lines. One is for the fuel pump to the fuel servo and the other is from the gascolator to the fuel pump. I can't think of anything else they could be. For the line from the servo to the distributor a -4 is typically used. A -8 is typically used for the oil cooler.
Gary Casey
Quote: |
Folks,
the etched SS tags
Ralph Capen |
