		Erich_Weaver(at)urscorp.c Guest
				 Posted: Mon Aug 23, 2010 10:49 am    Post subject: testing of backup alternator |
				Bob, your recently responded to a couple of posts from Jared Yates, who was asking (in part) about testing of the backup alternator in a Z-13/8 system.  Cant speak for Jared, but Im not sure his real question was effectively answered and I am interested in this as well,, so thought I would follow up.  How do I go about assuring myself that my SD-8 will work as advertised when called upon?  Can I just turn off the master, flip on the switches for the SD-8 and the  e-bus alternate feed, and wait to see if I get a low voltage warning light on my engine monitor?  Can I do this on the ground at idle, or do I need to have the RPM  elevated?  Feeling a bit boneheaded about this, but would be more boneheaded to not ask, and find out later my SD-8 was providing no backup at all.
  thanks for your service
  Erich Weaver
				 Posted: Mon Aug 23, 2010 8:56 pm    Post subject: testing of backup alternator |
				At 01:46 PM 8/23/2010, you wrote:
   	  | Quote: | 	 		  | Bob, your recently responded to a couple of posts from Jared Yates, who was asking (in part) about testing of the backup alternator in a Z-13/8 system. Cant speak for Jared, but Im not sure his real question was effectively answered and I am interested in this as well,, so thought I would follow up. How do I go about assuring myself that my SD-8 will work as advertised when called upon? Can I just turn off the master, flip on the switches for the SD-8 and the e-bus alternate feed, and wait to see if I get a low voltage warning light on my engine monitor? Can I do this on the ground at idle, or do I need to have the RPM elevated? Feeling a bit boneheaded about this, but would be more boneheaded to not ask, and find out later my SD-8 was providing no backup at all. |
    You can turn alternators on/off at any time under
    any conditions without regard to system safety
    or hazard to other components.
    The SD-8 does need a lot of RPM to produce full
    output. I doubt that you want to run a full-throttle
    preflight. During mag test you can turn the main
    alternator off and the SD-8 on. If the loadmeter
    shows ANY significant output, the alternator is
    probably fine even if low voltage warnings continue
    and the SD-8 output is less than 8-10 amps that you
    can expect at cruise.
    You can also wait until airborne and go to the SD-8 supported
    E-bus mode to test the system under more realistic conditions
    before you get too far from home.
                    (o o)
     ===========o00o=(_)=o00o=========
     < Go ahead, make my day . . .   >
     < show me where I'm wrong.      >
		longg(at)pjm.com Guest
				 Posted: Thu Aug 26, 2010 11:25 am    Post subject: testing of backup alternator |
				Erich,
 I didn't catch how many replies you had on this one. On my system I have
 a Dynon which monitors voltage internally and externally. Since I have
 the internal battery option, I can sit there with the SD-8 running (no
 interruption to the Dynon) and monitor the voltage activity on the
 master/essential bus via the Dynon. The key here is having something to
 monitor your system voltage that is not tied to switches and other
 things you've just lost when the alternator blows. That can come in many
 forms. I've seen some inexpensive LED panel voltage monitors that would
 do nicely.
 They're a nice feature to have when your world changes from inside the
 cockpit. A continued downward trend is warning enough to get down
 immediately. On the other hand you may feel you have enough output from
 the SD-8 to continue on to the next best/safest alternator shop (Pep
 Boys).
 Hopefully if you've reached that mode you've begun shutting off the
 air-conditioning, portable fridge, DVD etc. and are just running the
 minimums.
 On my ship the minimums take about 3-4 amps, Dynon, 1-radio, portable
 gps.
 Yes, the SD-8 seems to takes about a 1000 rpm to produce any sort of
 useable output. That may vary on your installation. If it's a sunny day
 I also have a solar charger to setup on the panel. That will at least
 power the GPS. And we're fly'n.
 Maybe the real question is whether it is worth real world testing - in
 my mind, absolutely. It's a great idea to test it in the air (better
 than on the ramp while your CHT's go through the roof) to see how much
 endurance you ultimately have. I would like to do the full test one day
 soon. Perhaps on a closed course over friendly terrain.
 I think most folks will wait for an emergency to perform the real test.
 In most cases that will be too late. It takes a bit of stomach to shut
 things down and really stretch the limit. I'm ok with that. You will
 want to land and re-start the main alternator after the test. From what
 I understand it's not recommended to re-start some of these alternators
 in flight. It may blow off the cowling and your firewall may melt.
 Best,
 Glenn E. Long
		deej(at)deej.net Guest
				 Posted: Thu Aug 26, 2010 12:22 pm    Post subject: testing of backup alternator |
				On 08/26/2010 03:17 PM, longg(at)pjm.com wrote:
  	  | Quote: | 	 		   From what
 	Would absolutely love to see some real data to back up this claim...
 Can you point us to any references?
 -Dj
 Dj Merrill - N1JOV
 Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
 Grumman Yankee Driver N9870L - http://deej.net/yankee/
 Join us on the New England Aviation Forums - http://forum.deej.net/
				 Posted: Thu Aug 26, 2010 4:16 pm    Post subject: testing of backup alternator |
				At 03:15 PM 8/26/2010, you wrote:
  > From what
    I've been testing alternators and generators on airplanes,
    laboratory test stands and an odd assortment of vehicles
    for 40+ years. We turn them on, off, no-load, full-load,
    you name it. Whether or not there's a battery on line.
    See chapter on engine driven power sources in:
 http://www.aeroelectric.com/Book/AEC12A_PDF.zip
    Having said that, there MAY be regulator characteristics
    (whether internal in or external) that present poor transient
    response without a battery on line. Indeed, this is one
    of the situations described by "load dump" in automotive
    parlance and "battery dump" in aviation parlance. Depending
    on how wildly the system behaves without a battery, SOME
    devices may be at risk if they're tied to the bus. This
    INCLUDES poorly designed regulators. This was the problem
    reported but not understood a few years back when some
    folks experienced alternator/regulator damage when switching
    a Z-24 system off with the alternator loaded. However,
    this is the exception.
    Bottom line is, as long as the battery stays tied to the
    alternator's b-lead, there's nothing you can do with
    switches on the panel that will hurt anything . . .
    In other words, transients generated by such activities
    do not exceed NORMAL operating transients as described
    in Mil-STD-704 and DO-160.  Even with Z-24 configuration,
    an internally regulated alternator worth your hard-earned
    dollars is not at-risk for inadvertent switch positioning.
		klehman(at)albedo.net Guest
				 Posted: Fri Aug 27, 2010 4:40 am    Post subject: testing of backup alternator |
				I definitely failed a John Deere PM regulator just by starting the
 engine on the ground with a totally dead battery. An immediate over
 voltage caused the crowbar OV module to trip the AC relay off, and the
 regulator evermore put out max voltage after the battery was recharged.
 I never have had a large capacitor in that system which might have
 helped. It was a sealed battery and they don't accept current for some
 time (if ever) when totally discharged. Undoubtedly the same failure
 would occur with a disconnected battery.
 Ken
  <nuckolls.bob(at)aeroelectric.com>
 > > From what
 > claim...
				 Posted: Fri Aug 27, 2010 6:01 am    Post subject: testing of backup alternator |
				At 07:28 AM 8/27/2010, you wrote:
 An immediate over voltage caused the crowbar OV module to trip the
 AC relay off,
       Hmmm . . . It may be that the JD rectifier/regulator
       has some feature a bit short on robustness . . . but
       the scenario you describe is not one that immediately
       suggests this. It's a certainty that yard maintenance
       equipment is quite often jump-started into a dead battery.
  	  | Quote: | 	 		  and the regulator evermore put out max voltage after the battery was
 recharged.
      This my have been an isolated failure. Have you replaced
      the r/r and found that everything works as expected?
  	  | Quote: | 	 		  I never have had a large capacitor in that system which might have helped.
      This would not have made any difference.
  	  | Quote: | 	 		  It was a sealed battery and they don't accept current for some time
     Maybe, but does the owner's manual for any item
     of JD equipment caution against operations with
     a completely discharged but otherwise good battery?
     I'm not sure you have enough data about the
     manufacturer's design goals to arrive at this
     conclusion. Certainly the scenario you describe
     happens many times on perhaps thousands of mowers
     and tractors every summer . . . if they were blowing
     up R/R like popcorn, I have to believe there would
     be some scrambling around in the JD engineering
     community to fix it.
     Obviously, my earlier comment to this thread
     pertained only to wound-field alternators. The
     permanent magnet devices with rectifier/regulators
     are another breed of cat.
				 Posted: Fri Aug 27, 2010 6:35 am    Post subject: testing of backup alternator |
				DJ,
 I do not but, based on Bob's generally reliable response I don't have to
 worry about pilot tales to complete my testing. As Bob indicated unless
 the battery is completely dead (not gonna happen in my case -on purpose
 - caus' the Lightspeed requires min 5 volts to run), I can safely switch
 on and off. That gives me the added comfort of continuing my flight say
 if the alt CB pops momentarily and I want to turn off the Alt to reset
 it. Naturally I'll only do that once in unknown circumstances.
 In most cases I could run a very long distance with the SD-8.
 One easy way to provide proof for yourself is to go out and do the
 tests. If so worried, turn off everything else first. If you don't know
 the limits of your machine, you don't know your machine.
 I'll be out testing.
 Glenn E. Long
				 Posted: Fri Aug 27, 2010 6:53 am    Post subject: testing of backup alternator |
				On 08/27/2010 10:31 AM, longg(at)pjm.com wrote:
  	  | Quote: | 	 		   One easy way to provide proof for yourself is to go out and do the
 Hi Glenn,
 	I've turned on and off the alternator with the engine running many
 times without incident.  In particular, I was taking mild exception with
 your statements:
  	  | Quote: | 	 		  > From what
  alternators
 	which I do not believe are true, and was asking if there were any
 references where this had actually happened.  I've certainly never heard
 of a cowling blowing off nor a firewall melting due to someone turning
 on their alternator...
 	Could be you were trying to be sarcastic, in which case I was hoping no
 one was actually thinking you were serious, and wanted to attempt to
 stop more Old Wives Tales on this topic...
 -Dj
 Dj Merrill - N1JOV
				 Posted: Fri Aug 27, 2010 7:32 am    Post subject: testing of backup alternator |
				Yes a replacement regulator has worked perfectly for several hundred
 hours.  You make a good point about the lawn equipment and dead
 batteries so maybe it was a one off failure. From what I've seen over
 the years though I think a dead flooded cell battery (as found in all
 the lawn equipment that I've seen) might have absorbed enough current to
 prevent the failure.  So my theory is that the sealed AGM battery was
 the critical factor. It was a totally discharged battery. Anyway thought
 it might save someone a hundred dollars and some hassle to mention my
 experience.
 Ken
 > An immediate over voltage caused the crowbar OV module to trip the AC
 > relay off,
 > recharged.
 > helped.
 > (if ever) when totally discharged. Undoubtedly the same failure would
