bgreen(at)bimi.org Guest
Posted: Mon Aug 30, 2010 5:26 am Post subject: Kolb-List Digest: 9 Msgs - 08/29/10 |
John Hauck:
Are your seats the type sold with the Mark III kit? or have you done something different. I firgure you have spent more time in them than others. Comfort is definently a consideration.
Does any one on the list have any type of "blower" installed on their aircraft? I refer to a blower that might be used to direct additional air over the cylinders during extended ground operations.
Does anyone have a preference on what brand of manifold pressure gauge to use?
Bob Green
Kolb MKIIIX builder
Posted: Mon Aug 30, 2010 5:38 am Post subject: Kolb-List Digest: 9 Msgs - 08/29/10 |
Bob Green
Bob G/Gang:
I never was a fan of fabric sling seats, although I flew with them a lot in
factory aircraft. They are comfortable and simplify construction.
I knew I wanted something a little more substantial if I crashed. While
building my mkIII in 1991 at the factory, I found two Ultrastar seats in the
attic of Homer's barn. Brother Jim welded up the seat frames and I
reinforced the plastic US seat backs with sheet metal. I also took some
advice from the JAARS pilots and riveted a sheet metal pan under my plastic
seat to prevent me being rammed through the 4130 seat frames should I have a
really hard landing.
I also use a piece of firm (green) Thermofoam in the seat to extend flight
legs from 30 minutes to several hours without getting butt cramps.
_________________ John Hauck
Titus, Alabama |
