email(at)jaredyates.com Guest
Posted: Thu Sep 02, 2010 4:04 pm Post subject: Splicing a shielded cable |
The dynon instructions call for a 4-conductor shielded cable from the panel to the remote compass. I'm planning to put the compass box in the wing, but would like to have a connector at the wing root to facilitate wing removal. What is the best type of connector to use in that case?
Joined: 28 Mar 2008 Posts: 1971 Location: Riley TWP Michigan
Posted: Fri Sep 03, 2010 4:03 am Post subject: Re: Splicing a shielded cable |
I am building a Van's RV-12 that has a Dynon D-180 with a remote compass located in the tail. The Van's supplied cable is not shielded. Instead, individual wires are twisted together. Since shielding is optional, I would not be too concerned about making a splice at the wing root. This application is not critical like a coax carrying a radio frequency. Any type of connector should work, like a D-Sub or even a 4 pin automotive trailer hitch connector. Since Dynon uses a D-Sub on each end, that would be good choice for the splice.
Joe
_________________ Joe Gores |
Posted: Fri Sep 03, 2010 4:42 am Post subject: Splicing a shielded cable |
Thanks Joe, that sounds like good information.
On Fri, Sep 3, 2010 at 8:03 AM, user9253 <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)> wrote:
[quote]--> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=311204#311204
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Posted: Fri Sep 03, 2010 7:11 am Post subject: Splicing a shielded cable |
At 07:03 PM 9/2/2010, you wrote:
in that case?
If the area is expected to stay DRY, then
a machined-pin, D-sub is fine.
