capt_riney(at)yahoo.com Guest
Posted: Wed Sep 08, 2010 12:41 pm Post subject: Mk3 throttle cable routing |
I'm trying to figure out how to run my throttle cables on my 582. I'm using CPS cables and 3-to-1 splitter. I'm thinking of mounting the splitter to a plate on the mag end of the engine (on the carb side) where there are a couple of unused inserts. From there would route the cable down the back of the cage through the fabric and then forward under the fuel tank to the throttle. My cage is covered 1/2 way up with the top of the covering level with the fuel tank, and I'm trying to minimize the number of holes I put in the covering. Curious as to what some others have done.
Mark Rinehart
Indy Mark3
