rickofudall
Posted: Thu Sep 09, 2010 4:39 pm Post subject: FAA Notice on re-registration |
FAA Safety Team | Safer Skies Through Education
Re-Registration/Renewal of Aircraft Registration
Notice Number: NOTC2543
On July 20, 2010 the FAA issued a Final Rule for Re-Registration and Renewal of Aircraft Registration. This final rule amends the FAA’s regulations 14 CFR Parts 47 and 91 concerning aircraft registration. Over a 3-year period, this rule will terminate the registration of all aircraft registered before October 1, 2010, and will require the re-registration of each aircraft to retain U.S. civil aircraft status. These new regulations also establish a system for a 3-year recurrent expiration and renewal of registration for all aircraft issued registration certificates on or after October 1, 2010. The re-registration will be conducted on a rolling basis beginning with all registration certificates issued in March of any year. Failure to re-register your aircraft will result in your registration (N-Number) to expire and make the aircraft ineligible to operate in the National Airspace System under any circumstances. See the attached notice for specific registration expiration dates.
Here is the notice as it came out today. Unfortunately, the attached notice did not arrive with this email.
Rick Girard
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
