tshank(at)core.com Guest
Posted: Tue May 02, 2006 4:24 pm Post subject: Rotor gap |
I'm trying to find out the the proper gap is between the magnetic pickup
in the distributor the the rotor that triggers it on a Stratus Subaru,
0.020 won't work and 0.011 will, but what is the spec on this?
Tim Shankland
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
Posted: Tue May 02, 2006 4:51 pm Post subject: Rotor gap |
Tim,
The factory gap setting is .008 to .016. A smaller gap will result in a
spark at a lower rpm than with the larger gap.
Play in the distributor shaft should not be allowed to take the gap out
of the tolerance range.
Taken from the instruction manual by Paul Messenger.
Larry McFarland - 601HDS at www.macsmachine.com
Tim & Diane Shankland wrote:
Tim Shankland
Posted: Wed May 03, 2006 4:42 pm Post subject: Rotor gap |
Thanks, that's what I was looking for.
LarryMcFarland wrote:
Tim,
>Tim Shankland
