dlm34077
				 Posted: Sun Sep 19, 2010 7:28 pm    Post subject: cowl mounted light |
				I found an instance this morning where a cowl  mounted landing/taxi light might have helped. I have the HIDs in the wingtips  and they focus and merge about 50 feet ahead of the aircraft. During taxi this  morning before daylight I followed the taxi lines over a rubber chock set. After  examination the nose pant rear fiberglass is cracked and I will have to  repair.   Still to be determined : whether this is due FBO stupidity  /carelessness or deliberate by some disgruntled airport visitor. The chock was  left on the centerline about 50 from the start of the movement area point. The  location is the only path between the runway environment and the majority of  hangars and covered tie downs. Authorities are still trying to determine why  they were there.. Of all the places to drop these chocks, if unintentional, this  is the only place on the airport guaranteed to cause damage in the dark. A  nose mounted light might have helped; the wingtip mounted lights  were disadvantaged by a 90 degree turn  prior.
