		deej(at)deej.net Guest
				 Posted: Tue Sep 21, 2010 11:14 am    Post subject: fabricating your own parts |
				Hi all,
 	I've seen various posts in the past concerning owner fabricated parts
 that can be legally used on our Grummans.  I'm curious where the line is
 between what we could fabricate, and what has to be factory made or
 TSO'ed, etc.  As a specific example, could we fabricate our own
 wheelpants?  In my case I'm talking about an AA1B, but this would
 probably equally apply to most of our planes.
 -Dj
 Dj Merrill - N1JOV
 Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
 Please use Netiquette Guidelines http://tools.ietf.org/html/rfc1855
 Kindly TRIM your email replies and post AFTER the relevant text
  |  | - The Matronics TeamGrumman-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		teamgrumman(at)YAHOO.COM Guest
				 Posted: Tue Sep 21, 2010 11:46 am    Post subject: fabricating your own parts |
				Get a copy of 14 CFR Part 121 and read up on what can be done under an owner produced part.  Garner knows a lot about this subject.  Ask him.
 The fact is, any part can be made.  The problem comes from trying to determine what needs a field approval or not.  Getting a field approval isn't trivial.  You do almost as much work as you would to get an STC.
 This is an area where you will need to do your homework.
 Sent: Tue, September 21, 2010 12:12:43 PM
 Subject: fabricating your own parts
  --> TeamGrumman-List message posted by: Dj Merrill <deej(at)deej.net (deej(at)deej.net)>
 Hi all,
 -Dj
 Dj Merrill - N1JOV
 Kindly TRIM
				 Posted: Tue Sep 21, 2010 12:13 pm    Post subject: fabricating your own parts |
				On 09/21/2010 03:35 PM, Gary Vogt wrote:
  	  | Quote: | 	 		   Get a copy of 14 CFR Part 121 and read up on what can be done under an
 Thanks, Gary.  I tried electronically searching through Part 121, and
 the word "owner" does not appear anywhere, "produced" only once in a
 different context, and "part" appears as "subpart" or "Part #" as in a
 section of the regs.
 I read through "Subpart L—Maintenance, Preventive Maintenance, and
 Alterations" thinking that might be the most likely place to find
 something, but I'm not seeing any reference to an owner produced part or
 similar wording.
 Do you have any more specific references where this might be found?
 Part 121 is pretty huge!
 Thanks!
 -Dj
 Dj Merrill - N1JOV
				 Posted: Tue Sep 21, 2010 12:52 pm    Post subject: fabricating your own parts |
				I found one reference, Part 21, Subpart K "Approval of Materials, Parts,
 Processes, and Appliances":
 21.301   Applicability.
 This subpart prescribes procedural requirements for the approval of
 certain materials, parts, processes, and appliances.
 21.303   Replacement and modification parts.
 (a) Except as provided in paragraph (b) of this section, no person may
 produce a modification or replacement part for sale for installation on
 a type certificated product unless it is produced pursuant to a Parts
 Manufacturer Approval issued under this subpart.
 (b) This section does not apply to the following:
 (1) Parts produced under a type or production certificate.
 (2) Parts produced by an owner or operator for maintaining or altering
 his own product.
 	So if you aren't selling the parts you fabricate, this section doesn't
 appear to apply.
 	I'll keep poking some more...
 -Dj
 Dj Merrill - N1JOV
		andy747(at)charter.net Guest
				 Posted: Tue Sep 21, 2010 1:08 pm    Post subject: fabricating your own parts |
				Hi Dj,
 I am an A&P and I have read the information you are looking for but I am too
 lazy to try to find it.  What I think it says is this....If a part is not
 available throught any normal sources, an owner may fabricate that part
 using the same materials and design....also, as I recall, you could design
 the part (as above), have it fabricated and have a properly licensed person
 install it....this was put in to deal with old airplanes that are no longer
 in production but applies across the board.
 If you really can't find it, I will look later....
				 Posted: Tue Sep 21, 2010 7:53 pm    Post subject: fabricating your own parts |
				my bad.  it is 21.  typo.
 Sent: Tue, September 21, 2010 1:50:05 PM
 Subject: Re: fabricating your own parts
 his
		Discover
